bought a 98 regal gs sc 3800 motor blown by previous owner when u trun sc pulley back and forth it kinda clicks like ther is play is that bad can anyone take ther belt off and see if when u turn it bak and fro if it clicks
thanks
98 REGAL
thanks
98 REGAL
its most likely its a coupler bud
its an easy fix ill find a link
Eaton - EATON Replacement Coupler #ETN-30858
ZZPerformance - ZZP Supercharger Oil #ZZ-SCOIL
^zzp claims you only need this one bottle
hexx yeah dude thats cake but from the vid the coupler looks likeit just sits on those 3 pins correct?thanks alot guys will def change it while its off car
yup just like you see it, 3 pins holds it on the gear, then 3 more pins are on the end of the sc pulley shaft, that slides into the 3 open holes left in the coupler, search ebay for the coupler, i got mine for 21 bucks shipped, went to a gm dealer for the sc oil, get 2 cans, you need 1 and 1/2 bottles, more or less. get a green coupler, not a black one.
yeah it just sits on the pins and lines up with the pins on the snout.
i see its 15 every where on the net is autozone gonna be same or close or no
autozone 16 99 thanks guys il de be doin the coupler before hand
ok thanks alot i actually live 1 hr away from zzp in gr michigan prolly contact them about pcm and coupler
that works good luck with everything
