Thread: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
Results 1 to 20 of 23
  1. #1 motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Mar 2012
    michigan
    do i ab solutly need the heads from the sc motor i understand the sc and intake but heads to ? didnt wana do extra work if i dont gota
  2. #2 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    http://www.grandprixforums.net/top-s...info-7763.html
    you do need the l67 or l32 supercharged heads
    LIM and blower need the heads to bolt too and the injector/plugs are moved
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  3. #3 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Mar 2012
    michigan
    ok i got all that forum wrote down to start tearing it apart i have a 98 regal gs with the sc 3800 and was planing to put a reg n/a 3800 in after i did the swap since the stock sc 3800 ws blown up but if u grab the puley and turn it back and forth the sc clickss like it has some play could the sc have gone out and caused the engine to mallfuntion to the preveus owner which i bought thew car already blown up
  4. #4 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    sounds like a coupler..
    wouldnt cause the motor to blow up
    my guess is the bottom end let go because of fauly LIM Gaskets
    // 2005 Comp G
  5. #5 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    that slop in the sc pulley didnt do any thing to your engine, its the coupler thats gone bad, its a 40 dollar fix and takes about 30 minutes to fix.
  6. #6 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Mar 2012
    michigan
    if its cheap fix do i have to do it before reinstallation is it gonna cause damage if not taken care of
  7. #7 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    id just fix it while its all apart
    easier to get to the 10 bolts
    // 2005 Comp G
  8. #8 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    // 2005 Comp G
  9. #9 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    then two bottles of gm supercharger oil and your set
    // 2005 Comp G
  10. #10 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Mar 2012
    michigan
    well i am doing a top swap to a n/a 3800 and installing it into my regal that is suposed to be sc can u find or can u explain how to change or replace sc coupler and if i dont do it will the sc mallfunction
  11. #11 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    ive heard it will eventually, but either way it will get annoying cuz at idle youll hear what sounds like rocks rumbling around in your motor
    and scotty put a link in your other thread
    // 2005 Comp G
  12. #12 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    as long as you have to pull the engine and do a whole swap, it would be in your best interest to get headers and have them ready to go in when you put it all back together, and a get your pmc tuned before you even have the engine finished, (canned tune if you dont have someone local to tune it in car) so you can drive it right away with out to much worries.
  13. #13 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    // 2005 Comp G
  14. #14 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    I'd go speeddaddies for headers.
    Do the coupler while it's out. Rollingperformance.com (instructions, parts, all you can need)
    You can put an SC on a car w/o doing the heads. It's called the SSM90 kit from ZZP $1300
  15. #15 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Mar 2012
    michigan
    do the headers that u suggested bolt directly to the stock down tube? that would be great and save tons of time oh and the stupid yard where i am to get my motor is slacking and havent even pulled it from the other vehicle should i go find a dif place to get my motor?
  16. #16 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    they replace the stock downpipe
    and thats up to you boss
    // 2005 Comp G
  17. #17 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Mar 2012
    michigan
    replace as in they bolt right to the stock then it should be food to go A are the headers really thjat important? unless my car is modded out which its not yet do i really need them?
  18. #18 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Nov 2010
    Maryville, MO
    you dont need them, but if you ever plan on modding i would go ahead and get them done now
    and they bolt up to the stock flange by the cat, they come with everything you need IIRC
    // 2005 Comp G
  19. #19 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Portland Oregon
    With the high compression bottom end, in short, you need them
  20. #20 Re: motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    Mar 2012
    michigan
    175 plus 50 shiping so 225 out the door thats the cheapest headers ive ever seen for the 3800 applications great deal unless anyone on here has a set of used or new ones i could check
  1. Pulling 99. 3800 motor...help please
    By slickandme in forum Introductions/Noob Questions
    Last Post: 05-02-2010, 02:53 PM
  2. GTP 3800 Motor swap into 2001 Grand Prix SE 3.1 body
    By HomeBoyShopnClub in forum General Tech Discussion
    Last Post: 08-19-2009, 07:45 PM
  3. Motor oil for 3800?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 07:04 PM
