Thread: prj fuel rainl/ injector help
Results 1 to 10 of 10
  1. #1 prj fuel rainl/ injector help
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    so I installed them they leaked I started changing injector o-rings with the o-rings zzp sent me for the swap but the o rings almost seem smaller than the old ones and when its all bolted down I can rotate the injectors I havent tried turning the pump on but do you need special O-rings for these rails or something
  2. #2 Re: prj fuel rainl/ injector help
    Pennsylvania
    Punctuation, for the love of god. Get bigger o-rings. Or get smaller fittings from Xtreme Racing Plumbing.
  3. #3 Re: prj fuel rainl/ injector help
    Quincy, Mass
    nope stock o rings. injectors are able to rotate when installed, thats normal. just make sure the orings didnt get pushed out of the side or anything.
    No more GP 04 Impala SS Indy:
  4. #4 Re: prj fuel rainl/ injector help
    I've always just used regular Felpro's. I think they are ES70599's. Whatever it calls for on our cars. Put them on, then lube them up with vasoline. Slide injecftors into rail and rail onto motor. Bolt down.
  5. #5 Re: prj fuel rainl/ injector help
    Quincy, Mass
    bill did you just pull that number off the top of your head.
  6. #6 Re: prj fuel rainl/ injector help
    Yeah Brian...I did.
    FWIW, it's right too
    http://www.grandprixforums.net/commo...ets-39796.html
  7. #7 Re: prj fuel rainl/ injector help
    Dec 2010
    Ohio
    alirght one of the o-rings was defenitly bad but while swapping them I noticed that the second nut on the hose connection don't know what its called was losse on the front and back rail so that might have had something to do with it
  8. #8 Re: prj fuel rainl/ injector help
    The injector fitting piece. Yes..that'll cause a leak.
  9. #9 Re: prj fuel rainl/ injector help
    Dec 2010
    Ohio
    ok so I hooked it all up and now the only leak I have is where the hoses go into the regulator adaptor will thread sealant hold up to gasoline?
  10. #10 Re: prj fuel rainl/ injector help
    Texas
    In my experience Teflon tape works the best.
    85 Corvette
    01 TA
    03 Z06
  1. Fuel Injector O-Rings
    By bobabooie in forum General Tech Discussion
    Last Post: 04-07-2011, 07:08 AM
  2. Fuel injector seating
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:42 AM
  3. fuel injector / pcm issues?
    By mastert429 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:43 AM
  4. Which fuel injector?? is there a difference?
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 09:55 PM
  5. Fuel Injector O-ring ????
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2008, 05:16 PM
