My fuel pump took a dump on me end of last week. i got a bit of help changing the pump out, and we couldnt get the new O-ring to fit and let us get the snap ring in place. so, without much other choice, we re-used the old O-ring. went right in. problem showed up today when i filled the gas tank. Filled the tank and noticed fuel leaking to the ground from under the car! i climbed in the trunk and removed the access panel, and sure enough, the pump assembly was wet with fuel. We didnt need to use any lubrication or anything on the old o-ring, but i am guessing that it isnt a tight enough fit to seal the gap??
are there any tricks you can offer that will help me get the new o-ring in place?
obviously silicone grease or similar... can i use something to push down on the pump assembly? maybe pry bar against the body and the pump?
