ok guys i have a 2000 grand prix gtp and it wont start.... ive narrowed down the problem to the fuel pump relay and pcm.. the pcm does not give power to the relay to energize it... ive already checked the ground to the relay and it turned out good... also a wierd thing ive noticed is that if i take the relay out, the pcm will supply power but as soon as i put the relay back in, the pcm no longer gives power to the relay... any ideas? THANKS
