Thread: have spark and fuel pressure. no start
Results 1 to 20 of 37
  1. #1 have spark and fuel pressure. no start
    GT Level Member m17davis's Avatar
    Orland Park, IL
    hey guys. its been awhile since ive posted. heres my problem. last week i had an exhaust leak in the headers. i fixed the leak. i think. first start after i resealed them it ran for 5 seconds. the same thing happened three more times. then it wouldnt start. it cranks but it wont turn over. i have spark and the proper fuel pressure. the weird thing is that i sprayed starter fluid down the TB and it would start for a little. any ideas? thanks in advance
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: have spark and fuel pressure. no start
    SE Level Member jaked1985's Avatar
    Jan 2012
    West Union, Iowa, United States
    There's a small fuse able link behind the battery, check that....
    My buddies gtx did the exact same thing you are describing last summer.
  3. #3 Re: have spark and fuel pressure. no start
    St. Louis
    It almost sounds like the car is running off the fuel after it primes the system, but then does not stay in low speed mode after the car starts. Maybe fuel pump resistor? You could always try the bypass method and bend the pin (pin 85?) out on the resistor and see if it will stay running.
  4. #4 Re: have spark and fuel pressure. no start
    Orland Park, IL
    Are you talking about the connection that has 2 black wires on one end and a green and grey on the other?
  5. #5 Re: have spark and fuel pressure. no start
    Orland Park, IL
    i replaced the resistor and it didnt go into low speed mode. so far ive replaced the maf the map and the iac.
  6. #6 Re: have spark and fuel pressure. no start
    St. Louis
    Can you leave the fuel pressure tester on the motor while you start/run it? I'd bet it shows pressure when you first turn the key, then it dies off as it runs. What is the fuel pressure showing anyhow?
  7. #7 Re: have spark and fuel pressure. no start
    Minnesota
    You sure you have spark? I would take the plug wires of one of the coils and see if it arcs between the two when turning it over. I would also check the grounding strap for the coils that is on the coil pack bracket.
    That sounds more like a spark problem than fuel.
  8. #8 Re: have spark and fuel pressure. no start
    Orland Park, IL
    yeah they arc. i got electricuted. lol the fuel pressure is 46 with the key on accessory. then when i try to crank it it jumps to 52. i just sprayed starter fluid down the tb and it ran with high rpms.
  9. #9 Re: have spark and fuel pressure. no start
    Jan 2012
    The gtx was acting exactly the same... run off ether, and carb cleaner for a short amount of time, had fuel, had spark... Small link in the wiring harness somewhere behind the battery, I don't remember exactly where, and don't see a diagram anywhere online to refer you too.. But, I'd be willing to bet that's ur problem..
  10. #10 Re: have spark and fuel pressure. no start
    Orland Park, IL
    do you know what it controls?
  11. #11 Re: have spark and fuel pressure. no start
    Jan 2012
    I do not remember what it was controlling, I just tried to get a hold of my buddy to see if he could remember what it was effecting, but he didn't answer.. I'll post an update as soon as I get ahold of him. It may be more of a resistor than a fusible link.. Either way, it was bad, causing the same issues. If anyone has a diagrahm of the under hood wiring, it should show it.
  12. #12 Re: have spark and fuel pressure. no start
    Jan 2012
    Rocky Mountain Club Grand Prix
    This was the problem. But, if this is the resistor you replaced.. I donno
    The symptom sounds right in line with this though..
  13. #13 Re: have spark and fuel pressure. no start
    Orland Park, IL
    No. I have not replaced that yet. Thank you so much. I'll let you know how it goes.
  14. #14 Re: have spark and fuel pressure. no start
    Jan 2012
    No problem. Hopefully it works for ya
  15. #15 Re: have spark and fuel pressure. no start
    Nov 2011
    south carolina
    Do you have injector pulse? Have you checked the injector fuse?
  16. #16 Re: have spark and fuel pressure. no start
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    X2^^
  17. #17 Re: have spark and fuel pressure. no start
    Orland Park, IL
    I have checked the injector fuse. How do i test the resistor.?
  18. #18 Re: have spark and fuel pressure. no start
    Jan 2012
    Quote Originally Posted by jaked1985 View Post
    Number five
  19. #19 Re: have spark and fuel pressure. no start
    Orland Park, IL
    Well i replaced fuel pump resistor, didn't work.
  20. #20 Re: have spark and fuel pressure. no start
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Any engine DTC's?
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. Car won't start << No Spark>> please help!
    By Pipeliner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2011, 08:40 AM
  3. Low Fuel Pressure on first start up. HELP!!
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2010, 11:43 AM
  4. HELP car won't start, got fuel, got spark, got air?
    By bezemom in forum General Tech Discussion
    Last Post: 05-29-2009, 02:19 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
