How hard can I pull on this before it breaks,, it is on there pretty good. Watching the how to video but they do not show how to get it off.I am trying to change my LIM gasket. Any thing will help
You don't need to remove that when doing LIM gaskets...
well I have to do the the UIM (SC gasket) gasket too. So either way it does not have to come off.
It stays on the blower..
I was a bit unclear guys the hoses is what I was talking about and not the sensor.
The hose going to the boost bypass valve stays on, the one going to the firewall pops out easily with a flat head screwdriver. thats all you need to remove.
Twist the hoses then pull. A twist will break them loose and then you should be able to pull them off. You might want to use a pair of needle nose pliers and push the vacuum hoses off. Hoses are easier to fix then the vacuum fitting on the supercharger.
ty sorry for being pain!
also do you have to get the gas out of the lines going to the injectors. Reading the Haynes manual it tells you to releive the gas pressure. iDo i really have to do this part. The bad thing is I have taken the belts off and drained radiator already.
You are disconnecting the fuel rail to replace the lower gaskets, correct? All you have to do is push on the bleeder in the fuel rail to relieve pressure.. They are probably telling you to get it all out to avoid getting any in the oil?.... But, if ur gonna do the work, change ur oil when ur done...
Yes I am will be disconnectiong the fuel rail, thanks for the advice on how to relieve the pressure. This is my first time working on this car and do not want to screw up anything. Once I am done I have to do the water pump too. Should be fun. As I go I am labeling everything and taking pictures. I am going to watch that video again.
No prob. I'm new around here, but I've been turning wrenches for quite awhile. Alot of the same things apply for any vehicle. Just take ur time when ur working on the motor... Labeling things and taking pics can be a huge help on the assembly process.
I already broke a nipple damn it, oh well live and learn. I still rather break a part of a hose rather then paying a shop 600 bucks to do this job.I have to do the water pump while I am at it. It sux because I need a long socket to get the coil pack off. Off to the store to get some tools.
Got the injectors off and notice ione of the gasket broken and one is missing. Also the hole where the injectors go are surrounded by dirt and oil. What's the best way to clean it?
Here is another pic of the injectors
This photo here the injector to the left is where the gasket is missing.
your going to need new O rings for the injectors. and Q tips work good for cleaning out the holes there.
it would have been best to have gunked/degreased the engine before starting the job to help clean things up, just clean all the parts you remove real good. dont clean the inside of the supercharger, just the outside. and clean your throttle body up real good while its off too.
put the injectors back in before you attack that... you dont want that washing into your intake runners.
S.O.B kind of worried some might have gotten in there.well I. Could but the injectors back in and try to clean around the holes. **** I am afraid of screwing my car up. Thanks for the quick response
yeah. thats what i'd do.
