Thread: Vacuum goes up when TCS is turned off?
Results 1 to 7 of 7
  1. #1 Vacuum goes up when TCS is turned off?
    Mullet Member Wotgtp's Avatar
    Connecticut
    While coasting(foot off the gas) on the highway with the traction control on, my vacuum was 13psi, when I did nothing else but turn the traction control off, the vacuum went up to 19psi. Da ****? Is there something that's vacuum activated in the TCS? It just seems really weird to me, and honestly I don't even know where to start looking for a problem besides obviously the lines but I don't know where the TCS stuff is.
  2. #2 Re: Vacuum goes up when TCS is turned off?
    um idk.
    But when you do start to coast the motor becomes a giant vacuum and pulls down lots of vacuum, up to ~25, noramlly it will only go that high after a WOT pull.
  3. #3 Re: Vacuum goes up when TCS is turned off?
    Connecticut
    It doesn't go near that. Even at a stop the car seems to do it. At idle I know I should be 18-22 but........it's not unless the TCS if off.
  4. #4 Re: Vacuum goes up when TCS is turned off?
    Ed..I have a vacuum gauge if you'd like a second source to check it. 13 is very low and to answer you question.. TCS is all electronic. Shouldn't have any effect on the motor at all.
  5. #5 Re: Vacuum goes up when TCS is turned off?
    Connecticut
    Thanks bill, I might give you a shout sometime soon to borrow it. This.is just weird.
  6. #6 Re: Vacuum goes up when TCS is turned off?
    Pennsylvania
    Quote Originally Posted by Wotgtp View Post
    1. You mean inches, right? Not psi? 13 psi is like 26 inHg, 19 is like 40 inHg (unless you pulled it off an airplane or something, I doubt your gauge will read that).
    2. Maybe the bypass was open and turning off TCS closed it, increasing vacuum.
  7. #7 Re: Vacuum goes up when TCS is turned off?
    Connecticut
    Lol good call, Yes you're correct.
  1. Intermittent no-start when key turned.
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2011, 10:00 AM
  2. Car won't do anything when key is turned in ignition
    By LJr22 in forum General Tech Discussion
    Last Post: 02-19-2011, 10:20 PM
  3. Can drilled and slotted rotors be turned?
    By corsagtp in forum Brakes/Suspension/Chassis
    Last Post: 04-11-2010, 01:55 AM
  4. HUD turned metric!
    By foghelmut in forum General Tech Discussion
    Last Post: 07-19-2009, 11:27 PM
  5. just turned 18! sick!
    By 2000GTP in forum Off Topic Discussion
    Last Post: 06-30-2009, 08:04 PM
