Thread: 04 gtp dosent want to start in cold weather
Results 1 to 19 of 19
  1. #1 04 gtp dosent want to start in cold weather
    SE Level Member Layten69's Avatar
    Dec 2011
    st.louis
    title says it all. when temps get below freezing it will act like it dosent want to start. i turn it over and it will act like it wants to start but then stalls. i have to try it three times before it starts but once it dose it will run fine. the front o2 censor is also out, could this have somethin to do with it?
    any feedback is appreciated thanks.
    2004 GTP (stock)
    1995 Eclipse GSX (not even close to stock)
    1966 Mustang (Wifes hotrod)
  2. #2 Re: 04 gtp dosent want to start in cold weather
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    gett a stronger batt
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: 04 gtp dosent want to start in cold weather
    Omaha, NE
    Get your battery checked atleast. Most parts stores can do it.
  4. #4 Re: 04 gtp dosent want to start in cold weather
    Dec 2011
    st.louis
    ok ill do that when i go to town today, any other suggestions in case this is not the problem? car is 100% stock BTW
    2004 GTP (stock)
  5. #5 Re: 04 gtp dosent want to start in cold weather
    utah
    battery battery battery
  6. #6 Re: 04 gtp dosent want to start in cold weather
    MO
    Don't always trust if the stores tell you the battery is fine. I've had that happen a couple of times to me. See if a jump start from someone else helps, or better yet borrow a battery out of a buddies GP and hook it up instead.
    <brandonl2000> LMAO D!!
  7. #7 Re: 04 gtp dosent want to start in cold weather
    Does it do the same thing with the maf unhooked? What do you mean by the front o2 sensor is out?
  8. #8 Re: 04 gtp dosent want to start in cold weather
    Dec 2011
    st.louis
    im not sure i havent tried that, and the front o2 sensor needs to be replaced.
    and it dosent do this all the time, just when the temp gets to below freezing. it has only done this to me twice.
    2004 GTP (stock)
  9. #9 Re: 04 gtp dosent want to start in cold weather
    Dec 2011
    st.louis
    and oncethe car is warmed up i can turn it off and it will start fine
    2004 GTP (stock)
  10. #10 Re: 04 gtp dosent want to start in cold weather
    Dec 2011
    st.louis
    i just went out and started it, it started fine the first try. i also checked the DIC and it says the battery is at 15.10 volts. any thoughts?
    2004 GTP (stock)
  11. #11 Re: 04 gtp dosent want to start in cold weather
    How do you know the o2 is bad? I'm thinking when the o2 is messed up the car goes into either open loop or closed loop i can't remember which but it won't want to start when cold because it won't give it the extra gas that it needs to stay running. Change the o2 and it should be fine.
  12. #12 Re: 04 gtp dosent want to start in cold weather
    Dec 2011
    st.louis
    the check engine light came on the other day and i had autozone run the code. i was also thinking this could be the problem but the only problem i see with your theory is that the first time it did this was before the check engine light came on.
    2004 GTP (stock)
  13. #13 Re: 04 gtp dosent want to start in cold weather
    the first time it did it could have been before the light was triggered but the code could have been pending. If you tell us the specfic code we could tell you probably whats wrong.
  14. #14 Re: 04 gtp dosent want to start in cold weather
    Dec 2011
    st.louis
    they didnt tell me the code, they just hooked the scanner to it and it told them the front o2 is bad. if needed i could go back and have them give me the code.
    2004 GTP (stock)
  15. #15 Re: 04 gtp dosent want to start in cold weather
    all our cars start in open loop and dont go into closed loop until (dont have my tuner in front of me) around like 100* engine temps...
    whens the last time the plugs were changed?checked?
  16. #16 Re: 04 gtp dosent want to start in cold weather
    Feb 2009
    flintnasty MI
    Quote Originally Posted by gtpsleeper View Post
    True, but the PCM will still use BLM cells in open loop. Very unlikely that it would cause starting problems though.
  17. #17 Re: 04 gtp dosent want to start in cold weather
    Dec 2011
    st.louis
    ive never replaced them i plan on changing plugs and wires when i get my income tax
    2004 GTP (stock)
  18. #18 Re: 04 gtp dosent want to start in cold weather
    Portland Oregon
    Check your fuel pressure. Mine does the same thing. I suspect the fuel pressure regulator. On your 04 it's in the tank on the underside of the canister lid. Problem is no one carries just the regulator for the 04. They want to sell you the whole assembly. Basically when it's cold, or it sits overnight the first start in the morning is rough. I've verified with a fuel pressure gauge that it takes a few key cycles for it to come up to pressure. It did this with my stock pump, and after a 255lph pump with a rewire.
  19. #19 Re: 04 gtp dosent want to start in cold weather
    Nov 2011
    south carolina
    If you have a "regular" gas station you use, try another brand.
  1. Cold weather starting!!
    By Madness in forum General Tech Discussion
    Last Post: 02-28-2011, 02:55 PM
  2. Cold Weather and Speakers
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2011, 06:31 AM
  3. Washing Your Car in Cold Weather
    By Traeger2591 in forum Off Topic Discussion
    Last Post: 01-12-2010, 11:06 AM
  4. Engine temparature on cold weather?
    By bmisita in forum Introductions/Noob Questions
    Last Post: 12-12-2009, 01:31 AM
  5. Oil Light Flickers in Cold Weather
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-30-2008, 07:12 AM
