Thread: Dropped pulley! I need help!!! Want 300hp!!!
Results 1 to 13 of 13
  1. #1 Dropped pulley! I need help!!! Want 300hp!!!
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    I dropped to a 3.2 pulley. Tuned it.
    From 259HP & 254TQ
    It got 266HP & 267TQ
    from 5 PSI went up to 7 PSI
    No Knock, just .01 to .04
    It produced 12 to 16 Horsepower till 5000rpms
    From 5000rpms to the redline, it only gained 5 to 6 HP
    I believe its time for springs and retainers.
    I will upload some pics of springs I have with retainers for help.
    The guy who tuned it told me it was not producing more horsepower up top
    Because of the supercharger getting too hot.
    It may be true. But i dont know
    My mod list:
    -Stage 1 intense blower cam
    -Fenderwell Intake
    -eBay headers
    -full 3" mandrel exhaust
    -autolites 104
    -180° thermostat
    -3.2 MPS
    -Shift kit
    everything else is stock
  2. #2 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Your valves are floating?
    Didn't we discuss this last time?
  3. #3 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Omaha, NE
    You should be on a 2.7 pulley that's where the power is.
  4. #4 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Nov 2011
    ok here's the deal.
    i have yellow springs and grey with some orangy markings
    been told that yellows were LS6 and greys LS7, LS3 & LS9
    heres the pic
    the middle one is grey the right one yellow and left stock L67 and the retainers ive got.
    they dont float
  5. #5 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Omaha, NE
    Something I've "been told", sounds like something I would throw power at for sure.
  6. #6 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Nov 2011
    what do you mean?
  7. #7 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Omaha, NE
    Do you know what they are?
    Did you install them?
    Have you even read the safely modding your 3800 thread?
  8. #8 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Nov 2011
    yellow are ls6
    greys were given to me
    the guy told me they were
    LS3, 7 & 9!
    i have not mounted anything yet because i don't know which is better
  9. #9 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Omaha, NE
  10. #10 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Jan 1970
    Maquoketa, Iowa
    the dyno chart and scan may help some.
  11. #11 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Troy OH
    weren't LS6 springs only like 90#? also, taking a shot in the dark here, but i believe those springs aren't interchangeable. aka the LS6, 7, 3, and 9 didn't use the same ones.
  12. #12 Re: Dropped pulley! I need help!!! Want 300hp!!!
    With that cam, you need springs or float is a given. Also the potential to break a spring is much much much higher with a stocker. If you don't know what the springs are, please..don't use them.
  13. #13 Re: Dropped pulley! I need help!!! Want 300hp!!!
    Wheeeeeeeeeeeeeee, valve float.
    Also, LS6's are blue now, no longer yellow.
    105's would be your best choice since they are easiest on the timing chain as well...which shouldn't be an issue because you should have replaced that with a new dampner when you installed the cam.
    If it was done correctly.
  1. whats it take to hit 300hp
    By 98GRANDPRIXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2012, 06:59 PM
  2. Dropped my car...camber is off.
    By Ballin00gtp in forum Brakes/Suspension/Chassis
    Last Post: 11-28-2010, 10:21 PM
  3. Dropped Boost After Headers
    By KFCOrBust in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 02:07 AM
  4. tuned and pulley dropped
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-26-2009, 11:57 AM
  5. Replies: 23
    Last Post: 05-31-2009, 09:01 PM
