Thread: "Service ABS, Traction Control, and Stability Control"
Results 1 to 5 of 5
  1. #1 "Service ABS, Traction Control, and Stability Control"
    Oregon
    I have a 2004 Grand Prix GTP Comp G with 55k. I haven't even solved the other problem I posted on a previous thread and I already have a new one. So it usually happens at low speeds when turning the steering wheel. While turning the steering wheel I can feel a bumping feeling. I then can hear what sounds like the rotor/hub assembly rotating from the front of the vehicle. Then on the DIC says "Service ABS, Traction Control, and Stability Control". It then shuts off my traction control (I can't turn it back on) and the ABS light stays on. I can shut the car off and the lights go away. When i start going again and I turn they come back on. It has been getting worse and more frequent. I have replaced both front hub assembly's so I am wondering if maybe my speed sensor is bad? The other thing I was thinking is maybe there is a brake sticking. Any thoughts would be appreciated, thanks.
  2. #2 Re: "Service ABS, Traction Control, and Stability Control"
    Pennsylvania
    Probably a bad ABS module. They're faulty from the factory. If you send it out to get rebuilt, it will come back bulletproof. The way to know for certain is to scan with a Tech II to see what codes are stored. Tons of information about this in other threads, just search for it.
    Ought to get you started.
    http://www.grandprixforums.net/ebcm-...ion-50176.html
    http://www.grandprixforums.net/how-u...bcm-52356.html
    Mercer, Pa
    They make abs/airbag/obd2 code readers now. Make sure you check that your vehicle year and model are supported. I got one from amazon. OTC 9450 $115.
    I had a traction control/abs/stability control lights. Ended up getting a junkyard abs module for $75. Solved my problem.
  4. #4 Re: "Service ABS, Traction Control, and Stability Control"
    Oregon
    **Update** I took my chances and bought a new hub assembly(It was under warranty). When I removed the drivers side front the wheel speed sensor connector was all messed up. Installed new hub assembly and problem fixed. Thanks for the suggestions though.
  5. #5 Re: "Service ABS, Traction Control, and Stability Control"
    GT Level Member Xorbex's Avatar
    Canada
    I have a 2005 Comp G with the Traction Control, Stability Control and ABS service lights coming on and then being disabled. Thought I would let you know my experience. Took it to a local shop and had it scanned and got codes "C0035 - LF Wheel speed sensor circuit malfuntion" and "P0703 - Brake switch circuit." Over the next few days I will change the speed sensor and give you guys an update.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. Traction Control/Stability System Module
    By teamfbody in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2012, 07:16 PM
  3. Traction Control/Service ABS
    By stealthee in forum 04+ Specifics
    Last Post: 07-28-2011, 10:19 PM
  4. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  5. 04 GTP Service ABS/ TRaction control
    By busagtp in forum General Tech Discussion
    Last Post: 09-07-2009, 12:03 PM
