Thread: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
Results 1 to 20 of 36
  1. #1 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Hey All
    I have been trying for the better part of 2 months now to
    isolate a number 4 cylinder misfire with no luck. I have put new
    plugs,wires and coils in with no help. I have changed the fuel
    injector;no dice, misfire still present. Took the car to Pontiac
    where a compression check passed. They had the car for
    over 3 hours and could not pin anything down. Did mention that
    the PCM driver circuit for number 4 fuel injector could be failing,
    but they were not sure. Got a used PCM with the latest GM
    software and still number 4 cylinder misfire. I have checked the
    the wiring to the injector with a home made LED and ran this
    inside the car. While the misfire is occuring the LED flashes
    nomally, so it appears the driver circuit for the injector is intact.
    Next tried hooking up the LED to the primary wires below the
    number 4 coil pack, no problems here either when car is misfiring
    the LED flashes normally. The hot wire to the injector is not breaking
    down either as this was checked as well with a wire running inside the
    car hooked up to multimeter. Meter showed 14 volts while misfire was
    ocurring. The car has 112,000 miles on it and I am the original owner.
    I thought perhaps knock sensors so I scanned the engine and here is
    where things get interesting. At idle the scanner shows -22 degrees
    ignition advance, does this make any sense. I scanned my fathers
    2003 Caddy and got a reading of 9 degrees advance. How can my car
    run at minus 22 degrees advance. Heres my question, is this a normal
    reading for a car that is supercharged or are these readings way off which
    I am inclined to believe. Appreciate any info you all are willing to part
    with and sorry for being so long winded.
    Thanks,
    Steve
  2. #2 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Quote Originally Posted by srlash View Post
    Hello All,
    Thanks,
    Steve
    Hi All,
    My Bad, I guess the scanner that I have reads a little different on
    my car. I guess the -22 degree reading is actaully BTDC and not
    ATDC like I originally thought. Sorry to trouble you all !!!
    Steve
  3. #3 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    That is way off... What have you done to the car? (mods) (new parts besides the ones listed above)
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  4. #4 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Bastard Reptile's Avatar
    Kansas City, MO
    What does the #4 plug look like?
    How about switching injectors to see if the problem follows it.
  5. #5 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Quote Originally Posted by Keet04GTP View Post
    Thanks for the Reply,
    Sir, I have done absolutely nothing to the car. The car is 100% stock
    like the day I bought it from the showroom floor. So the ignition timing
    is off I take it from your response. What should the timimg read at idle.
    Is it possible the timing chain might have slipped a tooth. I have swapped
    the injectors and the problem does not follow the injector. I have since
    bought a new injector for number 4 cylinder. Still no help. The #4 plug
    is not revealing anything either. It looks pretty much like the other 5.
    Thanks,
    Steve
  6. #6 Re: Removed
    Kansas City, MO
    I'm also assuming that you've switched around the coil packs?
  7. #7 Re: Removed
    Aug 2008
    Virginia
    Yes, and problem stays with the #4 cylinder. Just wondering does anyone here have
    the specs for ignition advance on a 97 Grand Prix GTP at idle, I mean does the number
    I am getting -22 degrees make any sense. Oh by the way, I purchased a new coil for
    #4 cyclinder and no help.
    Appreciate the Quick Feedback,
    Steve
  8. #8 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Kansas City, MO
    The actual timing on the idle should be around 22 degrees, that sounds about right.
    It is common to have a random misfire, but a multiple misfire that brings on the SES light could very well be a concern. I'll do some digging and see what I can find.
    are there any other codes that come up?
  9. #9 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Reptile,
    When nailing the car for 5-6 seconds this will bring on a flashing SES light for about
    7-10 seconds followed by a steady SES light. When checking for codes there is
    nothing, no codes period. When setting the scanner to monitor mode #4 cylinder
    is intermittently misfiring. I would have to say less intermittent and more actively
    missfiring is I would have to characterize it. It can not go 2-3 minutes without
    missfiring.
    Appreciate Your Help,
    Steve
  10. #10 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    PA
    I am not sure what this could be. But I am thinking something in the valve train? Would a failing lifter or bent valve cause a misfire? Hmmm...
    2001 GSE
  11. #11 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Could this condition escape a compression check. It occasionaly misfires at idle
    as well. Pontiac had the car for the better part of 3 hours and claims the engine
    is mechanically sound, although I wonder sometimes how thorough they were
    with the compression check. I wonder if an Ignition Control Module could cause
    a single cylinder misfire. Pontiac tells me that the ignition module is ok ???
    Steve
  12. #12 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Kansas City, MO
    If a lifter were to fail, you can usually hear it. Even if it were something along those lines it would most likely be constant and not intermittent. It also could very well be an ignition module.
  13. #13 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Reptile, that is what is such a pain in the arse with this car. I have driven a car
    with a burnt valve and it is a constant miss every time that valve opens it stutters.
    Perhaps a weak valve spring that allows the valve to float at higher rpms but that
    would not explain the miss at idle that I occasionaly have. I thought a blown
    head gasket between cylinders, but then I suppose I would have 2 cylinders
    misfiring.Maybe a worn camshaft???
    Steve
  14. #14 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Kansas City, MO
    Unless there is some type of internal engine failure, these camshafts don't wear out. They are a roller cam and hardly wear at all. However, given if there are a ton of miles on the engine, it could just be wearing out. Maybe carbon buildup on the valve...try seafoaming it. Weak valve springs can be it....it's just a bunch of possibilities that you just have to go through by the process of elimination.
    If it flashes the SES code then there should be something in the PCM like a P0300 code.
    An ignition module may be the culprit here, but I can't really say for sure.
  15. #15 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Reptile, At this time I agree with you, I think it is something electrical.
    Sometimes I can nail the car and when it shifts from 1st to 2nd gear the
    whole front end pulls up somewhat. It has plenty of power when it doesn't
    misfire. The question is, are there any other sensors that could cause a
    single cyclinder misfire. I am leaning toward the ICM as well, but from
    everything I have read on the internet, if it is failing then the companion
    cylinder should be misfiring as well. I guess there are exceptions.
    Steve
  16. #16 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    It could be something electrical, but I've seen a few GP's have some weird mis issues on cyl #4, and a tune has always resolved it... I still have no idea what the hell it was.... my old GT did it real bad sometimes...
    When my ICM went the car missed on two cylinders, and then just wouldn't start. Make sure you try and get a used one, or find someone to swap with ! Those ICM's aren't cheap !!!
    Lumpy Gen 3
  17. #17 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Jan 2009
    Crystal Lake, Il
    I have 1997 Grand Prix 3800 Supercharged with the same problem. mine is running at -20. I have replaced fuel filter, figured cheapest first, plugs, wires, havent gotten to the coil packs yet. money is super tight. My car will keep dying out though. Nobody has any idea what the problem could be. Any suggestions will be greatly appreciated. Is it possible to swap out coil packs to test for spark? on the same car, not from a different one.
    thanks again
    --Justin
    Hey All
    Thanks,
    Steve
  18. #18 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Aug 2008
    Virginia
    Hello Jmoney,
    Yes you can swap the coil packs as they are all indentical. What
    I ended up doing was removing the supercharger belt and the high
    speed fuel relay in the underhood electrical relay center. Problematic
    missfire gone. Next I ended up changing the coolant themostat. Car
    runs very well now. I suspect my car was never fully warmed up and
    was receiving too much fuel and when scanning the the car I always
    had 10% more fuel added to the base fuel curve. I have not hooked
    up the supercharger belt yet since I have to replace the snout drive
    seal due to it is leaking all over the place. Perhaps since the car was
    receiving too much fuel, and under supercharged conditions it was
    missfiring. I might also add that when the thermostat was failing I
    lost about 2 miles per gallon in fuel economy.
    Good Luck and keep me posted,
    Steve
  19. #19 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Feb 2008
    San Diego, CA
    Are you by any chance slowly losing coolant from your coolant recovery bottle?
    Are you aware of the LIM gasket issue on these engines?
    Impossible-to-trace misfires are sometimes a symptom of leaky LIM gaskets, intermittently wicking coolant into one or more cylinders.
  20. #20 Re: 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    i'm having the EXACT same problem with my car!! the only thing is i'm n/a.. same cylinder.. same symptoms.. checked the same things.. and just about the same amount of miles.. anyone have any info that can possibly help me?
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
  3. 92 Gran Prix Tranny
    By dvorak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2008, 12:31 AM
  4. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
  5. How do I install front license plate on 2006 Gran Prix
    By DMC-12 in forum Off Topic Discussion
    Last Post: 02-16-2008, 11:43 PM
