Thread: 98 Gtp wont start
Results 1 to 9 of 9
  1. #1 98 Gtp wont start
    Saskatchewan
    Heres what happened, backed my 98 gtp in to the drive way. popped the trunk got out, and the car slid forward on the icey drive way and when the car caught the dry pavement the tries rotated while the car was in park. Ive tried every thing. Went as far as to leave the ignition on the on position for ten miniutes. then to off then tried to start the vehicle. I am hopeing there is a simple sloution to my dilema! Please help. The vehicle was running fine up to this point!
  2. #2 Re: 98 Gtp wont start
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    put it in neutral and see if it starts. maybe a starter wire came off that was loose?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 98 Gtp wont start
    Omaha, NE
    Did your front tires spin or just the back?
    When you turn the key are you getting any power at all, headlights, radio, anything?
  4. #4 Re: 98 Gtp wont start
    Jul 2011
    NW Ohio, USA
    ^ ^ This.
    Also, when you say it "doesn't start" what do you mean exactly? Does it turn over? (Like Spade said) do you have any power? Make a clicking sound? Anything?
    I Gotz Moar Powar Than U Gotz
    The HWG Thread = Winning.
  5. #5 Re: 98 Gtp wont start
    What happened shouldn't keep the car from starting/cranking.
    The ignition switch sends a signal through the gear selector swtich (on top of trans) and that relays it to the starter.
    Maybe take a look, run it through the gears, trying to start in each gear.
  6. #6 Re: 98 Gtp wont start
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    I don't know much at all but would the anti-theft system have something to do with this by any chance? I know that some after market security systems have similar features that if the car is moved while the system is armed, it will prevent it from starting.
  7. #7 Re: 98 Gtp wont start
    Saskatchewan
    Thank you for all the replies still no luck. The car does turn over just wont start.
  8. #8 Re: 98 Gtp wont start
    Ok, we are getting somewhere.
    Are you missing spark or fuel?
  9. #9 Re: 98 Gtp wont start
    SE Level Member JcGTP39's Avatar
    Jul 2011
    Grand Rapids Michigan
    what i would do is disconnect negtive battery terminal and unhook the PCM leave it unhooked for 15-20 mins this should let the PCM reset it self once you connect it back and it gets power it should re scan the whole car then once it sees nothing worng it should be good hopefully.
  1. car wont start need help
    By 2001goldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2011, 09:02 AM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 97' GP GT wont start
    By AREED in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 06:28 PM
  4. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  5. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
