Thread: multiple misfires out of now where
Results 1 to 4 of 4
  1. #1 multiple misfires out of now where
    SE Level Member DunriteDiesel's Avatar
    May 2008
    Pennsylvania
    hello all. on my way home today and out of nowhere the serive engine soon light flashes for a few and the goes solid. i noticed at first the i was a little warmer then normal but around 200, not above. 0300 was the code, "multiple misfires". Does anyone have any ideas as far a sensors or any problems that my have arose. as far as maintence, the car was gone over bumper to bumper around 2500 miles ago...plugs, wires, coil packs, ALL fluids, thermos, hoses, battery...you name it i did it. Thank you for your time
  2. #2 Re: multiple misfires out of now where
    PA
    Quote Originally Posted by DunriteDiesel View Post
    First thing I would check is go over your plugs and wires. If you just did them, maybe you didn't tighten up a plug tight enough. Or maybe a wire rested on a manifold and burnt through. Maybe one wasn't on tight. So that would be the first thing I would check.
    2001 GSE
  3. #3 Re: multiple misfires out of now where
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    Quote Originally Posted by Zef_66 View Post
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  4. #4 Re: multiple misfires out of now where
    Saraland Alabama
    check all the tune up stuff, if that checks out check the cat
  1. Low fuel pressure/0300 misfires
    By Arkanzan Wheeler in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 12:59 AM
  2. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
  3. Multiple Vehicles in vBGarage
    By 98GP in forum Forum Bugs/Suggestions
    Last Post: 12-29-2007, 05:44 PM
