Thread: check engine light and lose wire in engine bay
Results 1 to 5 of 5
  1. #1 check engine light and lose wire in engine bay
    Long Island , NY
    I threw a chek engine light last night after looking around the engine bay i found what looking to be a pig tail for aa sensor just hanning down on the driver side of the bay. underneath the break master cylinder. the pig tail is blue and is clipped into the the cradle with only about 2 inches of play. i looked around and cant find any where fot it to go...Any ideas ...my thoughts as of now are is it pluged into some kind of extension that went to the exhaust for an o2 sensor...any help would b great ...thanx
    or evene a wire schematic would help.
  2. #2 Re: check engine light and lose wire in engine bay
    Omaha, NE
    What code came up when you had the Check Engine Light scanned?
  3. #3 Re: check engine light and lose wire in engine bay
    Long Island , NY
    dont have a scanner ....but the cars driving fine the remote start just stopped working
  4. #4 Re: check engine light and lose wire in engine bay
    In that area, that could be a two wire connector for power steering input, the brake fluid level sensor on the side of the master cylinder or something else. A picture would help tremendously.
    As for your remote start not working. Maybe the wire leading to the ICM for rpm input is unhooked.
  5. #5 Re: check engine light and lose wire in engine bay
    Long Island , NY
    I will upload a pic after work today
  1. Check Engine Light
    By Alpha388th in forum General Tech Discussion
    Last Post: 02-20-2009, 11:48 PM
  2. check engine light
    By keenan00gtp in forum General Tech Discussion
    Last Post: 12-01-2008, 10:25 PM
  3. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  4. Check Engine Light
    Last Post: 09-01-2008, 09:01 PM
  5. Check Engine Light
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 08:28 PM
