Thread: XPZ or XP/Nitrous
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: XPZ or XP/Nitrous
    Banned
    CT
    L36 is more likely to pop than an L32 or L67 though.
  2. #22 Re: XPZ or XP/Nitrous
    what going to pop?
    Pistons all around aren't great.
    Rod bolts fail as well.
  3. #23 Re: XPZ or XP/Nitrous
    Banned
    CT
    Ringlands on the n/a motors aren't as adequate for handling a supercharger.
  4. #24 Re: XPZ or XP/Nitrous
    ring gap isn't adequate for handing a roots blower pushed past 7 psi.
    0.010-0.018 in
  5. #25 Re: XPZ or XP/Nitrous
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Quote Originally Posted by SnowFlake View Post
    Seriously? I thought a lot of people used the L26 blocks for the compression bump.
    Huh? If I'm installing new rings, shouldn't this not matter?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  6. #26 Re: XPZ or XP/Nitrous
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    I would personally put the nitrous kit back on the Trans Am and step up the shot. LSx engines love nitrous. They stand up and applaud when you give them nitrous.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  7. #27 Re: XPZ or XP/Nitrous
    Laurel, MD
    Quote Originally Posted by TeeWX View Post
    It's still a possibility...I'm more inclined to run nitrous on a $200 junkyard motor rather than a $11,000 built motor. I'm not scared of nitrous, but I am well aware that accidents do happen, even on the best set up systems. If I feel the T/A needs more power, I'll piece together another kit, or just continue saving for a turbo.
  8. #28 Re: XPZ or XP/Nitrous
    Banned
    CT
    Quote Originally Posted by ls1camino View Post
    They do, but there's a certain amount of power/boost/rpm you shouldn't run on a stock L26... and that amount is a good deal lower than it is on the supercharged blocks.
  9. #29 Re: XPZ or XP/Nitrous
    Laurel, MD
    I'm thinking I should just get some forged pistons and be done with it.
    The likely hood of me finding a L67 or L32 motor around here is near impossible. I have a set of L32 rods I picked up awhile ago, so a set of forged pistons would match that nicely.
    OR, I could just order some hypereutectic pistons from ZZP...not sure what the future holds for this car, maybe a turbo. Would Forged Pistons be too much?
  10. #30 Re: XPZ or XP/Nitrous
    utah
    The future includes a lot of waiting if you order them from....well you know the deal
  11. #31 Re: XPZ or XP/Nitrous
    Laurel, MD
    If I don't go with the ARP Rod Bolts...are the stock rod bolts reusable? I read somewhere that they are not TTY bolts. Can anyone confirm or deny?
  12. #32 Re: XPZ or XP/Nitrous
    Jersey
    i vote stock l67/l32 bottom end
    my piston rings turned to **** on my 150k L36
    16' wrx sti- stock
  13. #33 Re: XPZ or XP/Nitrous
    As from what Ive read and seen around the 3800 forums bearings are likely to fail more often than the components so says PRJ too IIRC becasue the bearings are softer metal and junk by some standards. Tho I have no idea what other options would be available. I havnt seen many trashed components more thrown rod and cam bearings than anything. But what the hell do I know right?
  14. #34 Re: XPZ or XP/Nitrous
    You might want to run double the OE gap.
    People chip L67 pistons as well.
    Detonation weakens the pistons, they eventually chip.
    Top ring gap is way too tight for what we try and do with these motors.
    On rod strength:
    L26 < L36 < L67 < L32.
    Have to agree with rod bearing issues.
    It seems series II had **** quality control on the rod mass. Series III had much lower tolerances.
    I'd venture to guess this is significant in our motors considering they're externally balanced.
    Also: I actually found a thread where someone broke a stock crankshaft.
    Into three pieces.
    HOWEVER, had it machined so the workmanship is in question there.
  15. #35 Re: XPZ or XP/Nitrous
    On the broken CS...I really hope your not talking about Nick Manchen's pile in Chicago...that ****ing car...full of LOL's and it's 10:1 motor.
  16. #36 Re: XPZ or XP/Nitrous
    Can't remember.
    Machined crank.
    Sounds like bad news.
    No one seems to do machine work properly anymore.
  17. #37 Re: XPZ or XP/Nitrous
    Laurel, MD
    I feel I should make a new thread for the engine rebuild since the question I originally asked has been answered.
    It would help for future people searching for engine rebuild *shrug*
  18. #38 Re: XPZ or XP/Nitrous
    GTX Level Member crbquist's Avatar
    Massachusetts
    Not to hijack, but my motor is about to be complimented with an s1x and a gen v. It is a 104k L67 that runs perfect. I should be okay with the proper tune, correct?
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  19. #39 Re: XPZ or XP/Nitrous
    Jersey
    Quote Originally Posted by crbquist View Post
    are you going to run a double timing chain or a new stock gm chain?
    either will be fine with 105# crow springs
    16' wrx sti- stock
  20. #40 Re: XPZ or XP/Nitrous
    all we have to do is edit the tags at the bottom here as thats how things are searched.
    or if you want to make a new one thats entirely up to you.
  1. Nitrous?
    By MoBoost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2011, 02:43 PM
  2. How much nitrous can be ran?
    By basshead42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2009, 06:05 PM
  3. Nitrous, Dry or Wet?
    By japslpr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 02:32 PM
