Thread: Front exhaust manifold change help
Results 1 to 12 of 12
  1. #1 Front exhaust manifold change help
    Greensburg, PA
    Can anybody give me a quick summary of how to change this. I've got a front PEM and want to swap it but theres so much around the front exhaust manifold I'm not sure where to start lol.
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  2. #2 Re: Front exhaust manifold change help
    TDCRacing
    Guest
    Upper engine mounts. Spark plug wires. The 2 crossover bolts that bolt the manifold to the down pipe. Manifold bolts (6). and thats it i belive except a engine lift bracket wich i belive you have to take off.
  3. #3 Re: Front exhaust manifold change help
    Barksdale AFB, LA
    Take off the upper dog bone mounts:
    Remove plug wires (gently, if you have the stockers):
    Take out these two bolts holding it to the crossover:
    Best to soak them in PB Blaster for a while. Do NOT reuse them!!
    Remove this bracket:
    Remove any other brackets that might be in the way (nothing tricky). You will also have to pull the dipstick tube out. Just pull and it comes out:
    Remove the nuts and it will come right off:
    Some of the nuts may be seized to the exhaust studs. It's okay, as they'll still unscrew anyway. Only one of my studs actually stayed in the head, as you can see.
    While I'm posting pics... my front socker:
    Plog:
    Together:
    2009 Subaru Impreza WRX STI
  4. #4 Re: Front exhaust manifold change help
    Moore, Oklahoma
    Damn good instructions Sabrewings!
    Shawn W. Larsen
  5. #5 Re: Front exhaust manifold change help
    Barksdale AFB, LA
    Quote Originally Posted by Iron Indian View Post
    I had intended to make a guide for NAIOA, but right after the last few pics I broke a bolt in my rear manifold trying to get my crossover out. Never finished it.
    But thanks.
  6. #6 Re: Front exhaust manifold change help
    I live here. UR LOSN's Avatar
    Rockford, IL
    VERY VERY good write up!!!!
  7. #7 Re: Front exhaust manifold change help
    Oklahoma
    You need to get that into a document or something so we can post it up in the How To section, thats good information.
  8. #8 Re: Front exhaust manifold change help
    Barksdale AFB, LA
    What document type would you prefer?
  9. #9 Re: Front exhaust manifold change help
    Oklahoma
    Probably multi-format if you can do it, .pdf, .doc and so on. If you cannot do that then a .pdf file would be awesome.
  10. #10 Re: Front exhaust manifold change help
    Barksdale AFB, LA
    I'll see what I can do, throw some reinstall info in. Might not be immediately as I've got a lot on my plate at the moment.
  11. #11 Re: Front exhaust manifold change help
    Oklahoma
    No problem at all, no hurry either, just would be nice to have once you get the time to get it made up.
  12. #12 Re: Front exhaust manifold change help
    Greensburg, PA
    Yea thanks a bunch that defiantly made it go a lot smoother. I kinda figured thats how I'd have to go about doing it I just wanted to be lazy and not have to take out the extra like 5 bolts lol. thanks again
  1. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  2. How to Change Plugs
    By mainecrab in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2008, 07:09 PM
  3. Possible to change drive/driven sprockets in-car?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2008, 03:18 PM
  4. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
