Thread: Half boost?
Results 1 to 6 of 6
  1. #1 Half boost?
    Michigan
    98 GTP only getting half boost lately. I know i have a vacuum leak, but could that be the sole contributor? It got to the point of generating no boost and was throwing a TPS code, mechanic said it was a bad tps connector, changed the connector, now back to half boost. Ideas?
  2. #2 Re: Half boost?
    The boost control soleniod (rectangular electrical piece) can go bad and give partial boost. It's pretty common. However, I'd suggest fixing a known vac leak first, to keep from going lean once you get full boost back.
  3. #3 Re: Half boost?
    Topeka, KS
    Vac. leaks can cause all sorts of nasty problems. They can even effect the transmission and the way it shifts.
  4. #4 Re: Half boost?
    Oct 2011
    iowa
    Just went through this problem mine was the tensioner but if you have a known vac leak fix it first for sure
  5. #5 Re: Half boost?
    Nov 2012
    los angeles, ca
    i have the same problem so what was your fix? should i replace the solenoid or the bbv or both? disconnected the lower line that goes from solenoid to bbv and got full boost as well so plugged it back and went back to half boost
  6. #6 Re: Half boost?
    tennessee
    then get a new solenoid rock auto has em for under $40
  1. Getting half boost at the gauge.
    By falcz420 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:56 PM
  2. Half Boost PCV issue?? please help
    By Damon318 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2011, 11:52 AM
  3. half boost and bogging
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2011, 10:50 AM
  4. only have half boost
    By gtp225 in forum Introductions/Noob Questions
    Last Post: 09-25-2010, 01:32 PM
  5. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
