Thread: 3.2 installed!!!
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
  1. #1 3.2 installed!!!
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    So I installed it!
    Heres what happened
    The car is at 8-9PSI
    the a/f always stays at 11.8 at WOT
    In first gear I saw 1.6 KR At 6296 RPMS & 13*
    In second gear i saw 1.0 to 3.3 KR from 3976 to 5529 RPMS & timing from 14* to 9*
    After I let go of the throttle
    I see at 5000RPMS Timing going to 30.5 with KR of 4.7
    Experts! Let me know! I have more info if needed
    Mods are:
    Intense stage 1 blower cam
    Headers
    Lites 104
    180 tstat
    Full 2 1/2 exhaust
    Homemade FWI
  2. #2 Re: 3.2 installed!!!
    Omaha, NE
    What tune are you on?
  3. #3 Re: 3.2 installed!!!
    Out West
    Not enough timing.
  4. #4 Re: 3.2 installed!!!
    Nov 2011
    Was tuned in a dyno near home.
    What do you mean by not enough timing???
  5. #5 Re: 3.2 installed!!!
    Out West
    It means you're running garbage for timing at your pulley size and AFR.
    Get a new tuner.
  6. #6 Re: 3.2 installed!!!
  7. #7 Re: 3.2 installed!!!
    Nov 2011
    The car was tuned for the 3.4 and was at 17* or 18*
    And produced 260hp & 255tq with that set up
    I wanted to try the 3.2 and see what happens
    I cannot get a new tuner! He's the only one in Puerto Rico that tunes GM.
  8. #8 Re: 3.2 installed!!!
    Out West
    If you could only get 17-18* out of a 3.4 pulley and a cam, you're doing it wrong.
    And you only made 260whp from that? The torque number surprises me more though. 255wtq?!
  9. #9 Re: 3.2 installed!!!
    utah
    *facepalm "i wanted to try the (insert pulley size the car is NOT tuned for here) and see what happens"
    it knocks, chips pistons, and gives you a sad face. just cuz you "should" be able to and it just slaps on doesnt mean you should do it...ever./end rant
  10. #10 Re: 3.2 installed!!!
    go back to the 3.4 with more timing. whatever will leave you with AT LEAST stock timing (16*) and no KR is what you want.
    its also too lean for a non-intercooled car. shoot for 11.4:1.
  11. #11 Re: 3.2 installed!!!
    Out West
    I was thinking that as well. 11.8 on a non-intercooled car is lean to the point of diminishing returns.
  12. #12 Re: 3.2 installed!!!
    Nov 2011
    Ok, I asked and at another forum they told me that It can be fixed if I had low kr with a tune. Now what would you guys have me do? He's the only one in the island who can tune these cars.
    What numbers am I supposed to be seeing?
  13. #13 Re: 3.2 installed!!!
    you need to richen it up and add timing. whatever pulley you can run with those is what you want.
  14. #14 Re: 3.2 installed!!!
    Out West
    You were tuned for the 3.4....Run the 3.4
    If you want to run a 3.2, get tuned for it.
    You should be able to run 19* timing on that 3.2 at 11.4 AFR
  15. #15 Re: 3.2 installed!!!
    Nov 2011
    Ok, so im gonna change pulley tomorow
    What numbers am I supposed to see with the 3.4?
    And why is the torque bad?
    What can I do for a better tuner???
  16. #16 Re: 3.2 installed!!!
    Out West
    I run a 3.4 on 1.9 Rockers/LS6 springs, Headers, and Autolite 104's, on 14-17* timing -- I make 250whp/275wtq on this setup..
    Your numbers should be at the very least 20 more than what mine on both sides.
  17. #17 Re: 3.2 installed!!!
    utah
    just cuz he can tune them...doesnt mean he CAN tune them
  18. #18 Re: 3.2 installed!!!
    Nov 2011
    Ummm, so whats wrong then?
    Why is the tq so low?
    Whats going on?
  19. #19 Re: 3.2 installed!!!
    Out West
    The dyno isnt reading tq right probably is all it is.
  20. #20 Re: 3.2 installed!!!
    Nov 2011
    But i went to a mustang dyno and dynoed without the tune
    233hp & 236tq
    So what can I do for this tq thing?
    And what can I do to tune?
    The guy is the only one here! And its been known to be a good tuner!
    But I dont know now!
  1. Installed OEM Nav
    By richhurl in forum Audio, Security & Visual Electronics
    Last Post: 11-06-2010, 08:20 PM
  2. HID's installed!!!!!
    By tmackster in forum Visual/Body Modifications
    Last Post: 10-23-2009, 09:57 PM
  3. New CAI installed
    By dhall9 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 02:37 PM
  4. Got the new DP installed, but...
    By the1euge in forum General Tech Discussion
    Last Post: 07-21-2008, 08:07 PM
  5. First Mod installed. CAI
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 08:41 AM
