N* upgrade question
wpbboy81
I know everyone recommends using the LQ4 maf, but i see on 3800perfomance.com, they use a maf off the LS6 corvette. I know those would be harder (more expensive if new) to find. But i was wondering why isn't the MAF used off the cadillac that the TB is taken off of? Like if i were to go to the yard and pull a N* TB, why doesn't anyone use that MAF? I tried searching it, but didnt find any answers. Thanx in advance
dang, i figured u woulda knew lol. you've been helpful to me on all my posts (thanx also). It just crossed my mind cuz i was at the yard yesterday and was gonna take the whole setup, but recalled i never heard anyone talk about using it. so i came home to look it up and didnt see anything.
Ok, i did some research and according ZZP the LQ4 is popular because as they quote "
The LQ4 maf is cheap, and easy to replace if you ever need a replacement. It cross references to many different applications.
". i looked on autozone's website, and the 00-05 northstar engines use the same MAF part number as the 99-2000 6.0 engine chevy trucks. sooo, i'm guessing i can use the MAF from the caddy then
^^good work! this helps me out too:th_thumb-up:
off the subject how did u solve your pcv issue when doing the gen 5 swap did u run a line to your tb and if so by any chance u have a pic of it
yeah, i drilled and tapped a nipple underneath the tb and ran the hose that way. i'll go out and take a pic in a min
yer minute is up.
If you are N*'ing.. turn the vacuum port to the back (I use a say 13mm socket on a rachet as a lever) and then hose it.
yer minute is up.
thanx for that bit of info...i was going to need that in the near future:D, and also i was wondering which harness i needed, but that's answered also based on ur pic
If you have more questions. feel free to browse my pb account.
Photobucket.com
psd: Boosted (case sensitive)
Album for N* stuff is "Build up misc"
If you choose to look in there.. take a couple bottles of water and candy bars for energy. :th_laugh-lol3:
Photobucket.com
just to be clear, when N*ing, i connect the MAF hose to the adapter bracket's fitting, and the PCV hose to the fitting on the TB?
