Thread: best motor oil
Page 4 of 4 FirstFirst ... 234
Results 61 to 74 of 74
  1. #61 Re: best motor oil
    I don't know much about brand differences, I'd check out bobistheoilguy.com for that.
    I can say a little about the 3800 though. The difference between reg and synthetic oil is so dramatic, so incredible that it's hard to put into words. I'd rather run used synthetic than new reg oil. GM could have saved themselves millions in warranty claims and earned a better reputation just by putting a 'synthetic only' oil cap on the car. I have a short list of making the 3800 the best motor ever made but that's another story...
    THe 3800 seems to enjoy thin oil. Cars lube better and I made more on the dyno going thinner.
  2. #62 Re: best motor oil
    Nov 2011
    Kelowna, Canada
    Sure.
    Right after you turn it off, but if its been sitting no.
    Does it matter? Its time for 0W-20
    Well yeah it matters for me because It would be something I would look into. The RP would stay foamy fro up to 10 minutes after I shut my vehicle off. If mobil 1 was doing the same thing it would definitely change my outloook on the quality of RP. And I would probably start doing some more research. Which I probably will do anyways. If its just bubbly while the engine is runnin its somewhat understandable as it being heavily aggitated. But if its staying bubbly or foamy after the engine has been off then its something to look into.
    Make me curious if the foaming and bubbling is cause from the detergents or what, cause I really dont think bubbling and or foaming is supposed to happen.
    I dont know if the 0w30 is something id be interested in. i guess if its a bit thinner itd be ok for winters here. I frequently see -25-30 celcius here
  3. #63 Re: best motor oil
    Depends on whos 0W-30 you're running.
    If its castrol syntec, its thicker than their 5W-30 and 10W-30.
    Make you check the actual viscosity both cold and hot.
    0W-20 was not a typo either.
  4. #64 Re: best motor oil
    Nov 2011
    Kelowna, Canada
    0w-30 was a typo on my part.
  5. #65 Re: best motor oil
    Nov 2011
    NY
    Lol, I know this... Been driving for almost 35 years... Too many different cars to list, but maybe its just my old school brain!
    Burning or losing oil = "BAD"
    Never a good thing and certainly not a situation to have such a cavalier attitude towards, I.e., geeeeee its ok to burn a little between changes. I've never, ever, had an engine do that which caused me problems. Only those burning/losing oil were the ones that eventually had issues.
    Just saying...
    I wouldn't hypothesize over it, if you'd like to keep it fresh (engine) I would find out what the cause of loss is and take care of it.
    Regards
  6. #66 Re: best motor oil
    Nov 2011
    Kelowna, Canada
    coolone, Its clearly an oil issue if its only burned off royal purple and not the mobil 1.
    I talked to a local mechanic last night. He is a certified RP dealer(only shops around here that carry all RP products and not just the oil). He actually said a few years ago Royal Purple sent him a notice about their oil breaking down quicker than its supposed to. So it must actually be a brand/formulation issue.
  7. #67 Re: best motor oil
    Nov 2011
    Kelowna, Canada
    Found a half decent test
    Oils Against Oils - Major Oil Brands go head-to-head on the dyno.
    They rank the top 10 as follows
    1. AMSOIL
    2. BP Visco 5000
    3. Mobil 1 5w50
    4. Mobil 1 0w40
    5. Hi-Tec HTO
    6. Shell Helix Ultra
    7. Royal Purple
    8. Castrol R
    9. Castrol SLX
    10. Torco
    Kinda suck they didnt use the same weight oils in the test. But so far its the best one Ive found
  8. #68 Re: best motor oil
    Broken engines don't make any power.
  9. #69 Re: best motor oil
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by ls1camino View Post
    Obviously, you've reached the end of your intellect in that you resort to swearing and screaming (via internet).
  10. #70 Re: best motor oil
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    I do have to admit though, that had to be one of the most emotion packed gifs I've ever seen.
    I was using Castrol Synthetic at one point, people suggested I use Castrol High Mileage, but others said there was something in the High Mileage that wasn't necessarily good for long term use. I plan on trying out Mobil 1 synthetic or Amsoil if I can find a place that sells it nearby.
    2000 Midnight Blue Grand Prix GTP Coupe
  11. #71 Re: best motor oil
    Apr 2009
    Quote Originally Posted by Remnant King View Post
    agreed.
  12. #72 Re: best motor oil
    SE Level Member ibhuff's Avatar
    san diego
    I've been running that 0w 30 mobile 1 full synthetic advanced fuel economy with a wix filter. I would recommend visiting the great wall of oil at walmart and you can't go wrong. As far as filters are concerned check out this site.
    Rubicon Owners Forum - View topic - Oil filters
  13. #73 Re: best motor oil
    Apr 2009
    Interesting topic on the filter link you posted. Thanks!
  14. #74 Re: best motor oil
    Nov 2011
    NY
    Car Bibles : The Engine Oil Bible
    Just some interesting reading for those who might want some in depth info. On oils...
  1. used motor
    By craigcoble in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-06-2010, 07:59 PM
  2. Does anyone have a gtp motor that would fit my 04?
    By ray4was in forum Off Topic Discussion
    Last Post: 09-05-2010, 11:47 AM
  3. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  4. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
