Thread: best motor oil
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 74
  1. #1 best motor oil
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    tired of taking my car to shop to get the oil changed. whats the best oil out there for gtp's 150,000 miles btw
  2. #2 Re: best motor oil
    The one that lets you sleep well at night.
  3. #3 Re: best motor oil
    May 2008
    Winnipeg, MB
    I would like to see if Blackstone labs could release their oil TBN analysis results so we could all see how well engine oils really do.
    What's the best oil to use?
    Ah, the million dollar question. We are an independent lab, so we don't make recommendations. It has been our experience that oil is oil, and either petroleum or synthetic-based oil will work well for just about any engine.
    Come on, you're holding out on me. I should use synthetic, right?
    Buddy, you should use whatever you want. Synthetic oil won't guarantee a longer engine life any more than my eating organic food will guarantee I'll live until I'm 90. We here at Blackstone generally use regular petroleum-based oil because honestly, it works just as well for us.
    2007 Pontiac Grand Prix
  4. #4 Re: best motor oil
    There are benefits to using a thinner synthetic in the winter if your motor spends most of its time cold like mine.
  5. #5 Re: best motor oil
    Denver
    Also synthetic tends to be better for longer duration between changes.
    If you're going to stick with "every 3 months, 3k miles" then use whatever's cheapest in the appropriate weight.
  6. #6 Re: best motor oil
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    i personally use rp 5w30 in everything changed every 3k. i had actual dyno proof on my racebike that royal purple had a 1.3 hp gain and a .7 lb ft loss with royal purple vs the hp4 honda synthetic blend. but the bike is a completely different animal all together.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  7. #7 Re: best motor oil
    Indoors
    Synthetics while being more uniform at a molecular level have the benefit of having much better detergent packages as well as anti-wear agents and generally more of them. That's why some people say synthetic causes leaks on older cars..... it's true, sort of. It's just that synthetic and all it's cleaners will wash away more crud inside your engine that a cheap oil probably wouldn't. Sometimes dislodged trash in an engine opens up where a gasket had failed anyhow and voila, a leak is formed.
    My girlfriends 02 GTP is a perfect example. When I got it the engine looked like it was caked with mud inside ( literally, lol) because of neglect and LIM failure. Well about 14000 miles later at the last oil change I popped off the fill spout and looked around on the front head. The engine is cleaning up nicely inside and looks almost half respectable whereas before you couldn't see where the head bolts were as they were caked over. It also has a pretty severe oil pan gasket leak forming, but it actually was leaking when we bought the car.
    I would use a good quality oil and run whatever you want for changes. I don't do the 3K crap anymore, it's a proven waste. Even at 15K when I sent my last analysis in on some oil from my old work truck it was still clean and was deemed serviceable. I generally change between 6K-10K nowdays and use a decent quality synthetic oil. That's just me though.
  8. #8 Re: best motor oil
    Florida
    There's not really any 1 best oil out there.
    I use whatever is on sale/cheapest in the 10w30 Synthetic department.
    Just change your oil when it's due, dont over tighten the oil filter, and make sure to oil the gasket, and you'll be good, with whatever oil you choose.
  9. #9 Re: best motor oil
    SE Level Member baker01gt's Avatar
    Sep 2011
    houston, TX
    i personally use mobile one high milage full synthetic. although i started using it right after i replaced a leaking oil pan gasket, (pain in the azz job) because i heard it could cause the leak to get worse.. everyone i talk to likes the mobile one syth..
    recently ive started adding a little marvel mystery oil in when i do the oil change and also a little in the gas tank.. i will see how good everything acually works when i have my heads off next month!
  10. #10 Re: best motor oil
    Oct 2011
    iowa
    i use acdelco dexos1 synthetic blend for what its worth
  11. #11 Re: best motor oil
    Omaha, NE
    I use mobil 1 full syntectic mixed 75/25 with distilled water. Works great!
  12. #12 Re: best motor oil
    May 2008
    staten island,NY
    My Sierra with 180K gets whatever high mileage non synthetic is on sale, its a Gen 3 5.3 so i get piston slap no matter what at start up. The turbo GTP gets mobil 1 10w30 and either a K&N or Delco filter whatever is on sale.
  13. #13 Re: best motor oil
    i ran store brand oil and beat my car like crazy. make sure there is oil in the car.
  14. #14 Re: best motor oil
    Denver
    I have 141k miles and have only used Mobil 1 10w30 full synthetic (98 GTP).
    The heads with valve covers off look new (literally).
    I suspect this has more to do with proper change intervals than anything else.
  15. #15 Re: best motor oil
    Jul 2008
    Tampa, FL
    you can't say that on here, you know someone will actually try this...unless that is your goal....................
  16. #16 Re: best motor oil
    SE Level Member OldFart's Avatar
    Sep 2011
    Ontario, Canada
    I don't often hear Kendall Synthetic blend recommended. Supposedly for higher mileage cars. I find it to be a pretty good price point for a decent quality oil. Bottom line is, check it often, keep it at the proper level, don't let it go toooo long between changes
    Stock 2001 GTP
  17. #17 Re: best motor oil
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Quote Originally Posted by f3racer View Post
    This may be true, but with that being said, Oil is NOT meant to be a power adder by any means. Think about what is being given up to allow your motor to output more HP...lubricating abilities, reduced wear on the motor, and moderate cooling characteristics. Royal Purple has been tested against other brands and it scores the worst on all three tests. It runs hotter, does not reduce wear like it should, and really doesn't "stick" to parts like it should in the motor. All-in-all, it's crap and should be discontinued. The problem is that they have such a large advertising program that they can convince even the most hardcore racers into using it, and then they wonder why they spun bearings in their $25k mile motors or turbos destroyed themselves due to improper cooling and lubrication of the bearings.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  18. #18 Re: best motor oil
    GTP Level Member joshv's Avatar
    canada
    I just try and keep the same beand oil that has allways been put in it, using RP and knN filter every time when the oil system gets down to 20%
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  19. #19 Re: best motor oil
    Florida
    what weight oil? i just put in 10w40 at the suggestion of the mechanic that did my engine swap. being that we are in florida with our heat in all he said it was good to run a thicker oil.
  20. #20 Re: best motor oil
    I break stuff selliott's Avatar
    Kansas City
    I run amsoil or royal purple
  1. used motor
    By craigcoble in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-06-2010, 07:59 PM
  2. Does anyone have a gtp motor that would fit my 04?
    By ray4was in forum Off Topic Discussion
    Last Post: 09-05-2010, 11:47 AM
  3. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  4. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
