Thread: Catalytic Converter Questions!!!
Page 6 of 6 FirstFirst ... 456
Results 101 to 116 of 116
  1. #101 Re: Catalytic Converter Questions!!!
    Ignition control module = ICM.
    The brick that the coil packs bolt to.
  2. #102 Re: Catalytic Converter Questions!!!
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    oh ok, that makes a bit more sense. I think i heard about that at some point when looking at everything but I don't think it was ever actually looked at. Is there a way to test that without replacing it though? I also replaced the fuel pump to be sure it wasn't caused by lack of fuel at higher RPMs. Also, injector seals replaced, injector flush, valve cover gasket replaced, oil pan gasket replaced, water pump replaced, belt tensioner replaced, both belts replaced. I think the exhaust manifold gasket was replaced as well.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  3. #103 Re: Catalytic Converter Questions!!!
    They can test ICM's at some auto parts store, but alot of the time it can test perfect and still be a bad unit.
    If you know anyone with another 3800, take the few minutes to swap ICM's quick and take the car for a run, if the misfires stop, you found the issue.
  4. #104 Re: Catalytic Converter Questions!!!
    Nov 2009
    thanks I'll have it looked at. certainly a better start than straight up tuning it only to find it was the ICM.
  5. #105 Re: Catalytic Converter Questions!!!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Emissions carpus worthless if they don't test for it in your state then remove it end of story
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  6. #106 Re: Catalytic Converter Questions!!!
    Nov 2009
    I can't ethically remove a cat from my vehicle when i'm studying civil & environmental engineering. I want to keep it within the legal limits. I want to fix the misfires and get the car running up to par.
  7. #107 Re: Catalytic Converter Questions!!!
    Oct 2011
    Michigan
    It's not even that bad for the environment if you do it lol the movie vans should have it but it slows the car down and a performance car shouldn't
  8. #108 Re: Catalytic Converter Questions!!!
    Quote Originally Posted by UCF04GPGTPCompG View Post
    If you do some research you'll find out your car probably could run on an open downpipe for a year and not even touch the carbon footprint a hybrid makes on this environment, just food for thought
  9. #109 Re: Catalytic Converter Questions!!!
    Nov 2009
    What part of "i'm keeping my car legal" do you guys not understand? I need any help on diagnosing the problem and fixing it the legal way. Not cutting out a cat which is illegal since my car was made in 2004 with a cat required to meet it's emmissions requirements for that model year of vehicle.
  10. #110 Re: Catalytic Converter Questions!!!
    You have a HFC in the ZZP DP.
    I don't see how that's the issue.
    If it's tripping an SES light, just get the code tuned out via a tuner.
    Have you cleaned the TB in that thing recently?
    Basic tune up, plugs/wires/clean coil terminals, clean ICM surface and where it sits on the coil bracket?
    Seafoam the car?
    Just tossing out ideas for you.
  11. #111 Re: Catalytic Converter Questions!!!
    Oct 2011
    Michigan
    Your not a car manufacture lol that's only for if your selling the car bro if your state doesn't test for it lop it off
  12. #112 Re: Catalytic Converter Questions!!!
    Florida has no emissions...wat?
    The requirements for vehicle inspection in Florida are far simpler than they were in the past because Florida no longer has laws regulating vehicle emissions. Currently, vehicle inspections only verify that the vehicle being driven is, in fact, the same vehicle that is to be registered. In many cases, such as new vehicle registration and registration renewals, an inspection is not necessary
    Floridians, plz verify?
    Yup no emissions here 8)
    04 Comp G.
  14. #114 Re: Catalytic Converter Questions!!!
    Oct 2011
    Michigan
    Good another state that live able.....there's no way I'd live in a state with safety/emissions testing
    Me either. Or ill just do like one of my sisters who's in the service does and leave it registered in FL even though she's leaving in VA,WA for awhile. Screw that emissions junk.
    04 Comp G.
  16. #116 Re: Catalytic Converter Questions!!!
    Nov 2009
    Another point, why do you all assume that cutting out the cat would magically fix the misfires? It could be another problem, that's why I was asking in the first place. I'll have to get it diagnosed and hopefully get the issue pinned down. I think I'll take off the coils and ICM and clean that up some just to be sure it's not a connection issue at all. But anything requiring more work than that, especially computer diagnostics, wil have to be done at a dealer/shop.
  1. catalytic converter
    By mmerrittjr in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 11:49 PM
  2. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
  3. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
