Thread: [10-09-2013 ] 3800 swap&topswap Complete!
Page 7 of 7 FirstFirst ... 567
Results 121 to 124 of 124
  1. #121 Re: [update 08/8/13 ] 3800 swap&topswap
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Where's the inercooler?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  2. #122 Re: [update 08/8/13 ] 3800 swap&topswap
    I live here. DirtDog's Avatar
    Jun 2012
    Nice looking good
  3. #123 Re: [update 08/8/13 ] 3800 swap&topswap
    SE Level Member holyghost's Avatar
    May 2013
    Cincinnati OH
    I like your swap thus far. The digital cluster on that looks sweet, as does the bowtie and z34 on the throttle butterfly
  4. #124 Re: [10-09-2013 ] 3800 swap&topswap Complete!
    Florida
    Ok time to update this thread. Top swap install had a few hickups/ vac leak, bad ICM harness, bad fuel pressure reg. but after getting that all fixed, it is great! I completed post install tests to check everything. compression test shows 180 psi on all but one cylinder. the other showed 190 psi, 5% diff. Also did a coolant psi check and the system held 17 psi for 45 min without any drop. Vacuum looks great at idle. I have seen a peak of 7.5 psi at 6000 rpm. I had a peak of 3* of Kr when I started tuning and now I am pretty much Kr free.
    Ok here are some pictures and a short video of it running:
  1. Top swap 3800 SE
    By Austin2000SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2011, 09:51 PM
  2. 3100 sfi swap to 3.4l Dohc
    By Wigsos in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-27-2010, 03:04 PM
  3. Pics of my swap progress
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2010, 02:44 PM
  4. Engine swap - 96' 3.4l DOHC out, '93 3.4l DOHC
    By csbrown in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-11-2009, 04:47 PM
  5. Supercharged 3800 swap
    By biggz in forum General Tech Discussion
    Last Post: 09-06-2009, 03:07 PM
