Thread: first real problem
Results 1 to 7 of 7
  1. #1 first real problem
    Waukesha, WI
    start driving the car the abs light and tcs light comes on, i stop the car the lights go out. scanned the car pulled right front wheel speed sensor.
    checked the cable was firmly connected and looked good no cuts or nicks,
    assume bad hub?
    thanks for looking
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: first real problem
    London Ont, Canada
    id generally say yes.. but i is not as knowledgeable as some others.
  3. #3 Re: first real problem
    Waukesha, WI
    i replaced the pas side last year (timken) so i figured the driver side would go soon, i dont like shotgunning parts at cars anymore lol
    RayRay
    92 Turbo miata
    02 lexus is300
  4. #4 Re: first real problem
    London Ont, Canada
    fair enough, me nither..
  5. #5 Re: first real problem
    Sep 2011
    MI
    could ohm test it... Put an ohm tester on the two terminals... then rotate the wheel... if the numbers don't do anything probably the hub/sensor. If they change with the rotation go to the next plug and check there... 9 times out of 10 it is the hub though.
  6. #6 Re: first real problem
    Sep 2011
    Detroit, MI
    I just bought an '02 and am having the exact same problem. Lemme know what u find.
  7. #7 Re: first real problem
    Sep 2011
    Canada
    I had an Aurora with this problem. Ended up being the ABS wire. I bought a wire, cut into it and attached it and no problems afterwards. However, the wires in the hub can get bad when too much heat hits them. Had a car with a stuck caliper and was heating up the hub. Wires overheated and went bad and ended up having to replace the bearing because the wires went bad.
  1. Is this for real?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 03-30-2010, 07:31 PM
  2. Real Pay/Job
    By badbrad in forum Off Topic Discussion
    Last Post: 02-04-2010, 09:25 AM
  3. Third Grad Prix, First Real Problem
    By Bohunter21 in forum Introductions/Noob Questions
    Last Post: 08-30-2009, 04:10 PM
  4. is this for real!!!!?
    By justwhisen in forum Off Topic Discussion
    Last Post: 02-25-2009, 01:47 PM
  5. First REAL car 99 GTP
    By GTPJOE90 in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:19 AM
