Thread: Going to Replace Uim and Lim gaskets...what exactly do i need?
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    SE Level Member TomOfTarsus's Avatar
    Nov 2009
    near Pittsburgh, PA
    You're GOLD, my man. Local store says they have two. Thanks a million!
    err... what's with the Prius avatar on a Grand Prix web site?
    AAAANNNNNDDD the test ride went just great. Fully heated up, no leaks, runs smooth. Amsoil coming in Wednesday, we'll change out the cheap contaminated stuff.
    MUCH thanks again to matt5112. When you're at the end of a job like this and see that thing leaking you just want to throw a wrench through the garage door. Instead, a trip to the store and a few bolts and I'm back on the road! MUCH thanks. MUCH THANKS.
    Happy New Year to all!
    Tom
    Last edited by TomOfTarsus; 12-31-2011 at 08:04 PM. Reason: Fully together, successful test!
  2. #22 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    I don't know.
  3. #23 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Nov 2009
    near Pittsburgh, PA
    It's not a knock, I'm just curious. I drove one of those as a rental one time and was duly impressed. Atlanta, Georgia up to Kimball, Tennessee and back and forth to a plant in Alabama for a day or two, and 50-60 mpg the whole way. As an engineer, the use of regenerative braking and the whole power transfer/battery charging setup was fascinating. I hope we can get that kind of technology more widespread and affordable in the near future.
    Using the drag losses alone on my car (cAv^2) at 60 mph, the energy available in 1 gallon of gasoline should take me 210 miles or more. the fact that the best I can get is maybe 35 mpg in a level cruise at 60 mph shows that we have a lot of losses (mostly heat) that could be harnessed with the right technology.
    Thank you again for the parts advice you saved me a heckuva lot!
    Tom
  4. #24 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    I average 11 mpg currently with a motor making 267 whp in a 2002 grand prix. fuel economy has never been much of a concern.
    glad you got the part you needed. happy new years.
  5. #25 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    I am finishing up the LIM gaskets on my 97 and saw this post. I am sorry to ask maybe a dumb question but here goes- All the car has ever had in it has been mobil 1 synthetic and I am wondering if I should use that for even the "rinse" and short drive to wash out the motor or if I can use a less $ oil to do that since it will be in the motor for less than an hour or two. If I should stay with the mobil 1 I will but it seems silly if it's a throw a way. Any input is appreciated, thanks!
    Also do I need two oil filters or just change the filter at the end of the process?
    either get the felpro brand or the alluminum ones.
    Lim gasket
    Supercharger gasket (should come with 2 yellow o rings)
    valve cover gaskets and grommets
    tb gasket (unless yours is already the rubber re-useable one.
    RTV sealant
    coolant
    brake clean/razor
    10 quarts oil (buy cheap stuff,= for 5 of them, then the other 5 for whatever oil you want)
    oil filter
    After you have the LIM off and cleaned up, and befor you go to put it back on dump 1-2 quarts of oil down the valley to wash away any coolant/debris. Then drain the oil, and fill with 5 quarts oil and go drive it for 20-40 miles and then change it again. You must do this step to prevent any coolant from being in the oil and doing damage to the motor.
    If I missed something, I'm sure somebody will chime in.
  6. #26 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Nov 2009
    near Pittsburgh, PA
    For me, Oil is cheap & filters are cheap. I've gone from "whatever's on sale" to Amsoil back to whatever's on sale & back to Amsoil again. This time I used a cheap filter & regular oil for the "rinse" and followed it with Amsoil & one of their filters for the long haul. As a mechanical engineer, I do have to wonder what makes these synthetics so good compared to "regular" oil, but my son (who was helping me) sells it, so...
  7. #27 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Here's the kicker with the oil flush FFDP suggests. This is only if you get water in the oil. I do the job careful to not get any water in the motor. Then I fire it up for a minute and then change the oil.
    Reason #1 The steel oil pan most have on their motors (95-03) have about 3/8 of space below the drain plug. With water being heavier than oil, if you dropped a bit in there, it would be sitting in the bottom of the pan. Since I don't get much if any in there..it's not an issue.
    If you got a decent amount in though..then you absolutely want to drain it all off. Also once you are up and running, watch the oil for signs of milkiness. Change the oil until it's no longer milky.
  1. VC gaskets
    By dwelles in forum General Tech Discussion
    Last Post: 08-08-2011, 04:10 PM
  2. LIM Gaskets
    By RICE KILLER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 01:24 AM
  3. LIM Gaskets
    By jmac in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 02:12 PM
  4. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  5. Gaskets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 11:17 AM
