Thread: Going to Replace Uim and Lim gaskets...what exactly do i need?
Results 1 to 20 of 27
  1. #1 Going to Replace Uim and Lim gaskets...what exactly do i need?
    Sep 2011
    St. Cloud, MN
    Im going to soon replace my upper and lower intake intake manifold gaskets on my 02 GTP, ive done a lot of research and looking things up as far as doing it. I just want to know EXACTLY what i need, EVERY part i need to order. I know i need upper and lower gaskets and new o-rings for the injectors and gasket maker. Could someone point me in the right direction to every part thats good quality that i need with links? Thanks!!
  2. #2 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    GT Level Member NR92's Avatar
    Atkins, Ia
    just did them on my 04 gtp, i got lower intake gaskets, supercharger gaskets, valve cover gaskets/grommets, coolant elbows and a throttle body gasket, rtv sealant, coolant, would be a good time to replace filters, plugs, wires and to do an oil change! i ordered injector o rings but they came in late plus cost me $36 with my gm discount so i decided to return them
    im newer here so i might have missed something, but someone else will chime in
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  3. #3 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Sep 2011
    St. Cloud, MN
    did you get the regular gaskets or aluminum ones?
  4. #4 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Atkins, Ia
    aluminum, i would guess it would be hard to find plastic ones anymore
  5. #5 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    either get the felpro brand or the alluminum ones.
    Lim gasket
    Supercharger gasket (should come with 2 yellow o rings)
    valve cover gaskets and grommets
    tb gasket (unless yours is already the rubber re-useable one.
    RTV sealant
    coolant
    brake clean/razor
    10 quarts oil (buy cheap stuff,= for 5 of them, then the other 5 for whatever oil you want)
    oil filter
    After you have the LIM off and cleaned up, and befor you go to put it back on dump 1-2 quarts of oil down the valley to wash away any coolant/debris. Then drain the oil, and fill with 5 quarts oil and go drive it for 20-40 miles and then change it again. You must do this step to prevent any coolant from being in the oil and doing damage to the motor.
    If I missed something, I'm sure somebody will chime in.
  6. #6 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    SE Level Member TomOfTarsus's Avatar
    Nov 2009
    near Pittsburgh, PA
    Thanks gents! Yeah, I don't get on here too often but having threads like this makes it worthwhile. I have a 2003 GTP and the intake manifold has been leaking for some time. I thought the recall was supposed to fix that!
    My son is more of a wrench head than I am, and he was thinking we wouldn't have to disturb the supercharger, but it looks like y'all think it would be prudent even if the gasket is ok? Or can you not get the intake manifold off without removing the supercharger first?
    Fivefingerdeathpunch (), thanks for the oil change notice. Makes sense when you think about it.
    Now, if anyone is willing to post Step 1 - 2 - 3 pics, I'd be all !!! As well, are there any torque numbers to worry about? My son thinks the intake manifold bolts are torque-to-yield....
    Seriously, thanks for this. FWIW, I'm at 112K, and other than front wheel bearings and the recall on the engine top end (maybe it was the head gaskets?), this is the first serious maintenance I've had - well, just did the air conditioner condenser and one of my strut mounts is popping on turns, so I guess I'm due...
    Thanks again,
    Tom
  7. #7 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Get the metal gaskets, the plastic ones fail. And the plenum has torque specs and they should come with the plenum if you buy a new one. They tend to crack after the second torque down. Just so you know
  8. #8 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    you can take the supercharger off with the LIM, but its just alot heavier and a little more a pain to get back on with how bulky it will be.
    ALL the supercharger and LIM bolts are re-useable, they are not TTY.
    I cant remember the torque specs, but just get them pretty snug all the way around and you wont have problems. I've seen LIM bolts snap at the proper torque specs for no reason, so that why snug is good enough.
    Watch this.
    http://api.viglink.com/api/click?for...13174000148283
  9. #9 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Quote Originally Posted by Points70 View Post
    Ummm, sure...on L36 motors...this is the supercharged section.
  10. #10 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    I am finishing up the LIM gaskets on my 97 and saw this post. I am sorry to ask maybe a dumb question but here goes- All the car has ever had in it has been mobil 1 synthetic and I am wondering if I should use that for even the "rinse" and short drive to wash out the motor or if I can use a less $ oil to do that since it will be in the motor for less than an hour or two. If I should stay with the mobil 1 I will but it seems silly if it's a throw a way. Any input is appreciated, thanks!
    Also do I need two oil filters or just change the filter at the end of the process?
    Lim gasket
    RTV sealant
    coolant
    brake clean/razor
    oil filter
  11. #11 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Sep 2011
    St. Cloud, MN
    Thanks for all the responses guys!! I got all the stuff ordered and plan on replacing it all next weekend... any random tips/tricks about the whole process i should know??
  12. #12 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    its pretty straight forward.
    I'd come and help since you live pretty close, but I'm not sure if I got time.
  13. #13 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Sep 2011
    St. Cloud, MN
    yeah it seems pretty easy, i guess we'll see when i start.lol ...if you happen to have some free time id appreciate the help! ill supply food and beverages for the entire day.haha
  14. #14 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    St. Cloud, MN
    Where you at in St. Cloud? I'll come help you.
    PM some details.
  15. #15 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    From the many LIM gaskets I've done in the past this might help a little.
    Take off the bolts for the t-stat, remove it, and stick the hose from a wet-dry vac on there and suck all the coolant out of the LIM. This will make removing the LIM easier and not drip a half a gallon of coolant into the motor (or anywhere else).
  16. #16 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Waseca MN
    looking at doing this fix my self.. I have a small puddle under the car, under the oil cap I see some coolant. Upper or Lower?
    03 Khaki Rubicon
    RE
    4.5" Long Arm
    98 GP GT as the DD
  17. #17 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Nov 2009
    near Pittsburgh, PA
    alpine2g,
    Sorry, I don't know - I'm one of those looking for help... and HOLY KAZOY! So I pull the plastic cover off and it's a warren of wires and tubes criss-crossing the supercharger. Okay, so you unplug the wires and I think the tubes are all for the fuel injectors, but I didn't see anything about them above, and yeah, it's bad enough that this is "what I did on my Christmas vacation" but then to ask y'all to help out, well, I feel sheepish, but if anybody's free to type a little... That video is taking forever and two days to download.
    It looks like to get the front valve cover off, the top engine mounts have to be undone (this is a 2003 GTP), and the back cover is nearly invisible. Maybe I can skip those? Just do the LIM gasket? I hope my son has seen stuff like this before!
    Big thing for me so far is the injector rails, I didn't realize I'd have to remove them, so I'll be looking about, but if anyone has anything... I numbered the wires coming off the ignition moduls, & thank heaven for digital cameras!
  18. #18 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Nov 2009
    near Pittsburgh, PA
    Ok, with access to the manuals over at GPONA, and my son's expertise, we have the manifold out. Our only side trip so far was the valve covers, I'm going to look but it seems like you have to take the whole front of the motor off to do them, 'cause we sure can't get them out.
    Yup, there's a lot to do just to change the valve cover gaskets. Unreal...
    Last edited by TomOfTarsus; 12-27-2011 at 09:13 PM. Reason: checked the manuals - YOW!
  19. #19 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Nov 2009
    near Pittsburgh, PA
    You're GOLD, my man. Local store says they have two. Thanks a million!
    err... what's with the Prius avatar on a Grand Prix web site?
    AAAANNNNNDDD the test ride went just great. Fully heated up, no leaks, runs smooth. Amsoil coming in Wednesday, we'll change out the cheap contaminated stuff.
    MUCH thanks again to matt5112. When you're at the end of a job like this and see that thing leaking you just want to throw a wrench through the garage door. Instead, a trip to the store and a few bolts and I'm back on the road! MUCH thanks. MUCH THANKS.
    Happy New Year to all!
    Tom
    Last edited by TomOfTarsus; 12-31-2011 at 08:04 PM. Reason: Fully together, successful test!
  20. #20 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Nov 2009
    near Pittsburgh, PA
    Well, we're all back together aaaaaaaannnnnnnnnd - the plastic elbow at the front of the manifold is leaking. Yep. So is there anything better for this, or do I have to visit the dealership. I notice there are two of these beauties, so get them both, pull the alternator and tensioner and pop them in, or is there something easier?
    Thanks all.
  1. VC gaskets
    By dwelles in forum General Tech Discussion
    Last Post: 08-08-2011, 04:10 PM
  2. LIM Gaskets
    By RICE KILLER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 01:24 AM
  3. LIM Gaskets
    By jmac in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 02:12 PM
  4. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  5. Gaskets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 11:17 AM
