Suddenly my Stop Lamps, Interior Dome/Map Lamps and cigarette lighter has stopped working. I already replaced Ignition switch, fuses,turn signal switch, BCM(Body Control Module), Brake switch, Relays..... Still the
damn problem persist. I checked the voltage on the fuses there is no power coming through the fuses, I have 2 separate fuses for the lamps...one states as INTERIOR LAMP, and the other one states as STOP LAMPS both fuses are just fine but no Power coming or going through them. Also my high mount brake light is not working but the rest HID and parking lights, hazard and left and right signals are working. I don't know what else to look for? All fuses/Relays are fine in the panel....any help/guidance/suggestions will be appreciated!
