Thread: AL 104 spark plug showing misfires...
Results 1 to 9 of 9
  1. #1 AL 104 spark plug showing misfires...
    Apr 2011
    sudbury
    decided to try the Al 104 back into my car and the aeroforce shows "2" misfires on a few cylinders now and then.... is that normal? there brand new plugs . had 0 misfire with stock ac delco .....that how i know its plugs....
  2. #2 Re: AL 104 spark plug showing misfires...
    Omaha, NE
    What's the gap on the 104s?
  3. #3 Re: AL 104 spark plug showing misfires...
    Texas
    Pull the two plugs. I have a feeling that one of those will probably be cylinder 6. Not uncommon to accidentally crack the porcelain on the plug. Also double check to make sure your wires are snug and they "snapped" in place.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: AL 104 spark plug showing misfires...
    Apr 2011
    sudbury
    Gap at 53. Tgou and no they arent cracked and rubbers snapped on good
  5. #5 Re: AL 104 spark plug showing misfires...
    random misfiring is a 3800 staple. it happens even on healthy stock motors.
    im assuming this is at idle?
  6. #6 Re: AL 104 spark plug showing misfires...
    Apr 2011
    sudbury
    Yes on idle . Ive been running the plugs for a few hrs now and its getting better.
  7. #7 Re: AL 104 spark plug showing misfires...
    modded 3800's LOVE to misfire at idle.
  8. #8 Re: AL 104 spark plug showing misfires...
    Pennsylvania
    Would having spark plugs 2 ranges colder than you should cause misfires?
  9. #9 Re: AL 104 spark plug showing misfires...
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    2 years late, yes
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  1. Bent plug tips and misfires
    By Knightmare in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2011, 11:45 AM
  2. Spark plug gap
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 01:55 AM
  3. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  4. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
  5. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
