Thread: Engine Coolant Question
Results 1 to 12 of 12
  1. #1 Engine Coolant Question
    Jul 2008
    canada
    This might be a silly question but I am doing it for the first time and don't know much about cars so i need some advise please. My coolant light comes on when i start the car. After driving it for 5 minutes it goes off. I am thinking to add some coolant. I know the plastic coolant holder on the driver side under the hood. I will add to that. Do i also have to open the radiator cap on the passenger side and add there as well. My car is 1998 Grand Prix GTP.
    Thanks
  2. #2 Re: Engine Coolant Question
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Add to the overflow bottle only. There is a line a few inches from the bottom,that you fill to. IF you over fill, when it gets hot, it will come out the over fill tube on the back side of the bottle. I overfilled once and for the longest time I though I had a leak. I parked on a slight hill one day and heard the dripping. Man I was happy that day.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Engine Coolant Question
    SE Level Member hotshot's Avatar
    R.I.
    Make sure you check the coolant. If it is red it still has the factory dex-cool wich cannot be mixed with the yellow stuff. If you need to add you have to add dex-cool or a certian prestone that will say on the bottle that it is safe to mix with any other coolant. Otherwise it will gel up and or turn into a sand like slugde and that will be a problem.
    98 GTP - slp powerflo cat back, built tranny, AP104s, homemade FWI and intense 180 stat.
  4. #4 Re: Engine Coolant Question
    Jul 2008
    canada
    Thanks a lot for your valuable advise. I looked at the coolant bottle but there are no marks anywhere indicating LOW or FULL or something that tells me the limit. Can i fill upto half bottle?
  5. #5 Re: Engine Coolant Question
    St Louis MO
    The line is barely above where the hose from the radiator connects. I would only go 25% if you don't see the line. btw there are no words just a raised line the same color as the bottle, which makes it hard to see.
    2010 Camaro SS LS3
  6. #6 Re: Engine Coolant Question
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by hotshot View Post
    Green stuff cannot be mixed; if it is yellow it is supposed to be safe to add to any coolant. I have only seen the stuff made by Prestone.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  7. #7 Re: Engine Coolant Question
    Jul 2008
    canada
    I checekd the radiator. It's filled upto top. I also filled enough coolant in the reservoir bottle but my lights still stays on. this is what happens. When i start car in the morning it stays on for 5-7 minutes and after that it goes off. Could this be because of bad sensor? Where is the coolant level sensor in 1998 Grand Prix? Is this something i need to replace right away? By the way temperature stays within acceptable limits.
  8. #8 Re: Engine Coolant Question
    SE Level Member phat_ridegt's Avatar
    Ottawa, IL
    if the light stays on and the radiator is full, change the coolant level sensor located on the passenger side of the radiator. very easy to do. pull headlight, use a screwdriver to remove metal clip, and pull it out. if your fast enough, you wont lose too much coolant.
    XP|I/C'd GEN V|ZZP TRANS|
    11's or BUST
  9. #9 Re: Engine Coolant Question
    PA
    2001 GSE
  10. #10 Re: Engine Coolant Question
    Oklahoma
    Very nice Zef.
  11. #11 Re: Engine Coolant Question
    PA
    Very nice Zef.
    Courtesy of Eric on clubgp...aka Houndi.
    2001 GSE
  12. #12 Re: Engine Coolant Question
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    Am I due for a round of part replacements as I'm about to hit 100K miles? I replaced my MAF sensor a week ago, and this morning my LOW COOLANT light came on. I replaced the UIM in April, so theoretically any coolant leak was fixed. My overfill tank was at about the house line, and I had some quick fill so I was able to fill it up. But I haven't seen a leak, and my oil didn't look gooey or that any coolant was in it.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  1. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  2. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  3. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  4. Coolant leaks
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2008, 10:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
