Thread: ??ported Supercharger??
Results 1 to 17 of 17
  1. #1 ??ported Supercharger??
    Peachtree City GA
    So i wanted to get some info on gettin your eaton ported.. Some questions are
    1) What is the rough horsepower gain from lets say a complete (inlet+outlet) port packege from zzp?, assuming a 3.4 pulley and all supporting mods
    2) Does porting reduce enough knock to allow a pully size drop?
  2. #2 Re: ??ported Supercharger??
    Apr 2008
    Chillin at the Beach , VA
    For a ported s/c, thalk to reptile. He's the man when it comes to this subject.
  3. #3 Re: ??ported Supercharger??
    Bastard Reptile's Avatar
    Kansas City, MO
    I got your email, and replied to ya.
  4. #4 Re: ??ported Supercharger??
    this will not give you any gain really unless you are running a sub 3.0 pulley. its almost easier to do on your own for the amount of gain youll get (extend the V and polish the inlet).
    now if you have an intercooler and a bigger throttle body, that makes sense to open up the inlet more and to knock out the wall on the underside.
    when i take mine off next for my SSIC im going to plug up the silencing slots so i can get some more whine out of it.
  5. #5 Re: ??ported Supercharger??
    TDCRacing
    Guest
    Is that all that does? have you heard the difference between the 2 before?
  6. #6 Re: ??ported Supercharger??
    i personally have not heard the difference..yet.
    will advise on that though, i want more whine and im sure you do too.
  7. #7 Re: ??ported Supercharger??
    TDCRacing
    Guest
    Yeah please don't forget about me.
  8. #8 Re: ??ported Supercharger??
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    if you are paying for a blower and it doesn't look straight and smooth like the picture here http://www.grandprixforums.net/51639-post6.html then you are getting hosed.
    The ported blower is a support thing. You won't feel any difference and it doesn't allow you to drop pulley sizes.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  9. #9 Re: ??ported Supercharger??
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    I want a whiney blower... How do I plug this hole... I feel like I'm starting over learning about these cars.... I have been out of the loop for soooo long...
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  10. #10 Re: ??ported Supercharger??
    use something similar to quicksteel. thats what im gonna use when i have my blower off. ive heard of people using black rtv, but i just dont trust it.
  11. #11 Re: ??ported Supercharger??
    TDCRacing
    Guest
    There is no way any rtv would work. How to do it properly? Weld them shut. How to do it if you can't weld them? JB Weld,Quickseal ect. Like bio I think mentioned earlier though I wouldnt do jb weld or quickseal enless i had an intercooler. Just incase it decided to break loose one day it wouldnt be sucked into the engine.
  12. #12 Re: ??ported Supercharger??
  13. #13 Re: ??ported Supercharger??
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    where are the Silencing slots. What do they look like
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  14. #14 Re: ??ported Supercharger??
    Jul 2008
    Tulsa
    Where are these slots? Does anyone have any pics?
  15. #15 Re: ??ported Supercharger??
    they are the slots that are surrounding the triangle inlet. one on each side.
    supposedly someone got ahold of eaton and found out they are for keeping the blower noise down since a grand prix is a family economy car in all retrospect.
  16. #16 Re: ??ported Supercharger??
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    well then when i pull my sc and intake to do my zzp vs swap i might as well weld them shut and make the V bigger
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  17. #17 Re: ??ported Supercharger??
    Banned
    Wichita Falls, Texas
    im weary on welding them for fear of the case warping.
    But your okay with doing a half ass job and risking that chunk of crap coming loose and going into your intake?
    Quote Originally Posted by YoungGTP
    Don't mess with the size of the 'V' all you need to do is smooth the edges of it up and take the chunks of metal out where the bolts screw into from the snout.
  1. Ported LIM?
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 03:02 AM
