I have been looking for help or a post for about week searching for information on doing the flush problem, i have found posts about it, but not really really thorough about their issue so here i am asking for help. Apologies if there is a post about this and i just didnt see it i guess "/
Just finished replacing the coolant elbows and im now flushing the coolant.
1st Problem: The radiator plug is in the bottm right hand corner of the car. The plug is plastic with a hex. My tools cant get them in because of the awkward position i have to be in so, to make it easier, remove the under panels?
2nd Problem:Panels under the car consist of removing 2 or 3 screws and 2 tabs, done. But i cant get it out! It looks like i have to push down and pull them out, once i get to that part, the right side is almost out, just need to pull the left side, left side will not move at all, right before it gets to the point, it just stays stuck. The middle of the panel, well idk, gotta get the left side moving first.
So thats where i stand, and literally this baby is almost done! Just do this, get rid of the abs light and check engine light and then, pass smog this and that, and im good to go! Thanks for the looks and help. pics would help too thank you!
