Thread: No Throttle response after IC install?
Results 1 to 17 of 17
  1. #1 No Throttle response after IC install?
    Wichita
    Just installed the ZZP St2 IC core & for some reason I barely get any throttle response. Car's running fine, no leaks. The pedal feels loose & I have to push halfway down just to get a response...what the eff?
  2. #2 Re: No Throttle response after IC install?
    Omaha, NE
    Did you forget to hook the throttle cable back up?
  3. #3 Re: No Throttle response after IC install?
    Wichita
    they are very hooked up.
  4. #4 Re: No Throttle response after IC install?
    Wichita
    The car runs great. It's just...I hafta push the pedal down a lot farther than I used to to get the car to move. Its really odd. Could moving the throttle body up 2.25" make the throttle cables loose enough that it affects throttle response? Or is it something else?
  5. #5 Re: No Throttle response after IC install?
    make sure your cables are nice and tight. make sure the throttle blade moves smoothly. make sure the cables move smoothly.
    you gotta help us out here, help us diagnose.
  6. #6 Re: No Throttle response after IC install?
    Omaha, NE
    Madonna - Like A Virgin (video) - YouTube
  7. #7 Re: No Throttle response after IC install?
    Wichita
    I tightned the cables. That should do it.
  8. #8 Re: No Throttle response after IC install?
    Wichita
    Nope didn't make a difference. For some reason I now only get 40% throttle. And that's with the pedal smashed to the floor. Could it be a TPS issue? I'm kinda stumped.
  9. #9 Re: No Throttle response after IC install?
    Omaha, NE
    Did you tighten it or loosen it?
  10. #10 Re: No Throttle response after IC install?
    Wichita
    Okay okay. Everythang seems nice n' tawght tharr. Throttle responds fine when I pull the throttle bracket. Responds like Pooh when I push the pedal. I mean 40% max?
  11. #11 Re: No Throttle response after IC install?
    either the cable has a balls ton of slack or your TPS sensor is way off and needs adjusting.
  12. #12 Re: No Throttle response after IC install?
    Wichita
    The TPS is relatively new but it hasn't been messed with recently. So then, I must be overlooking slack somewhere?
  13. #13 Re: No Throttle response after IC install?
    Quincy, Mass
    theres a TPS relearn that you can do. i think its with car off but in the run position, you put the gas pedal to the floor 3 times in a row and that does it. you should search for it though because im not positive thats the procedure.
    the other thing, is you hood hitting the cable bracket when you close the hood? when the bracket goes up it might be hitting the hood and getting stuck. you can bend the bracket a little and then adjust your cables again or take the pad off the hood to give you more clearance.
    No more GP 04 Impala SS Indy:
  14. #14 Re: No Throttle response after IC install?
    GT Level Member RegalGS98s's Avatar
    NJ
    Have someone sit in the car and slowly push the pedal. Look under the hood while they're doing that and see if the throttle moves.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  15. #15 Re: No Throttle response after IC install?
    Wichita
    I'll do that & check to see if the throttle cables are catching on the hood. It's a pretty tight squeeze to shut the hood now & many parts are rubbing. I just nvr thought to check the cables for rubbing/catching.
  16. #16 Re: No Throttle response after IC install?
    Portland Oregon
    When you push the pedal to the floor is the throttle blade actually opening up all the way? Can you take pictures of your throttle cable where it attaches? I think you have it in the wrong spot.
  17. #17 Re: No Throttle response after IC install?
    Wichita
    Erhm....I found the problem. Throttle cable wasn't attatched properly(I put it back together in the dark lol). Problem was deff' user fail
  1. Delayed throttle response when cold
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2011, 11:14 AM
  2. Steering response
    By Aeroheadcww in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2011, 07:19 AM
  3. rpms jumping no throttle response at all???
    By nate49707 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2011, 08:06 AM
  4. Troubleshooting Help! p0133/p1133 Slow response o2
    By Lawngoose in forum General Tech Discussion
    Last Post: 12-29-2009, 08:39 PM
  5. 2005 Grand Prix throttle response
    By j obernesser in forum General Tech Discussion
    Last Post: 08-17-2009, 05:27 PM
