Thread: Supercharger coupler replacement
Results 1 to 20 of 21
  1. #1 Supercharger coupler replacement
    Ohio
    anyone change out the snout to case gasket??? if so anyone know how to find a part numbe rfor advance auto parts??? i just called and the guy knows nothign about cars
  2. #2 Re: soupercharger coupler replacment
    Mercer, Pa
    No gasket, they just use sealant.
  3. #3 Re: soupercharger coupler replacment
    michigan
    Hahahahaha....*soup*ercharger
  4. #4 Re: soupercharger coupler replacment
    Ohio
    it was very soupy when i pulled it off lol... if i torqued down the bolts everyone think its going to leak without sealant???? if so i might pull it back off...
  5. #5 Re: Supercharger coupler replacement
    Anaerobic sealant.
    it'll leak without it.
    You want some on both sides of the rotor pack plate.
    Not much though, small bead.
    http://www.permatex.com/products/Aut...ket_makers.htm
    Any of those should work.
  6. #6 Re: Supercharger coupler replacement
    Jul 2011
    B-Town, PA
    I actually used ultra black (598B) and it sealed perfectly. It's not a huge deal to remove the snout or pack to redo if an issue arises but i regularly check my fluid and haven't seen any decrease in about a weeks time.
    between rotor pack & case and snout and rotor pack.
    used factory eaton replacement coupler
    used 8oz oil
    easy swap.
  7. #7 Re: Supercharger coupler replacement
    RTV only cures when exposed to air.
  8. #8 Re: Supercharger coupler replacement
    Jul 2011
    B-Town, PA
    I had black on hand. i used it per recommendation from a set of rebuild instructions i encountered online. If left to cure without the oil in the snout (plug out) for a few hours it will be just fine. Otherwise use the appropriate anaerobic sealant.
    as stated my fluid level has stayed put for a week now and there is no residue on the lower manifold/gasket area so i know it sealed up. Others may not be so lucky. Just stating what worked for me.
  9. #9 Re: Supercharger coupler replacement
    Ohio
    i think i sealed it... when i filled it there was a puddle but that could of been from it dripping or something from pouring it... ive been watching the fluid closely... i left it empty for 2 hours and then filled it... if it drops any all re do it... it only took a little bit to tear down and put back together... i will watch it carefully im pciky though and dont like re using fluid so ive bought 4 bottles so far and have 2 spares lol
  10. #10 Re: Supercharger coupler replacement
    Wichita, KS
    You can use RTV, I would suggest the Ultra Gray made by Permetex. This is what I only used back in the day, still works great, and it does cure, and it does seal. NEVER had had a issue with any of my M90s out there.
    You ONLY want to do ONE SIDE of the rotor pack, the side the snout mates up to. A thin light bead of sealant too...don't over do it.
    Its zero tolerance on these parts when they go together. You do want to use a anaerobic sealant though, to correctly do it. Loctite 518 is what I would use. The stuff I use is actually from Detroit Diesel through my brothers shop. Its similar to the 518.
    When the snout goes on, its 22 ft. lbs of torque.
    GenV's you want to also add sealant to the lower two, center most bolts on the unit. They tend to seep oil out if you don't. This was a correction fix from Magnuson, fixing Eaton's little boo-boo on that. Eaton now puts sealer on every snout bolt on the later made units.
    ~F~
  11. #11 Re: Supercharger coupler replacement
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    So, why wouldn't you just do it right the first time? Just because you did it with RTV doesn't mean it's right.
  12. #12 Re: Supercharger coupler replacement
    PA
    Agreed. Just because it worked for ya once does not mean it is the correct way to do it. And should not be suggested to someone on a forum that might not know what to watch for.
    2001 GSE
  13. #13 Re: Supercharger coupler replacement
    Wichita, KS
    The RTV I was using does work, I have used it for years, on countless superchargers. That's why I offered that info.
    I have since switched to the Loctite 518 (or comparable) for the units I am rebuilding to this day. Both work, one is just better over all.
    I don't offer bad advice, ever.
    ~F~
  14. #14 Re: Supercharger coupler replacement
    ~F~
    LMAO, alright Jason.
  15. #15 Re: Supercharger coupler replacement
    Wichita, KS
    I'm going to take the high road on this one, and not even post what I had typed as a reply to your comment. I know you will reply to this, cause you always feel you have to get the last word in. I'll chat with you in person next time I see you Nick, don't worry.
    ~F~
  16. #16 Re: Supercharger coupler replacement
    PA
    ~F~
    Last word. I just got it.
    Well, until someone else posts.
    2001 GSE
  17. #17 Re: Supercharger coupler replacement
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    worrd
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  18. #18 Re: Supercharger coupler replacement
    Bastard Reptile's Avatar
    Kansas City, MO
    You know, it's pretty sad that you've got to keep egging someone on. That's not taking the high road dude, you're basically daring him to reply.
    Using RTV is NOT recommended, they did NOT come like that from Eaton. I've never recommended using it to seal the rotor pack, and I've worked on several cars that have a leak, because of the fact they used RTV to seal the snout to the rotors. Be they got the info here, club gp, or wherever, it's false information, and in fact if it doesn't get squeezed out of the joint, it doesn't cure half the time and ends up inside the oil.
    Argue all you guys want about what to use, but if you use RTV, then in my opinion it's misinformation and I'm not going along with it.
  19. #19 Re: Supercharger coupler replacement
    Wichita, KS
    I figured you would like the "high road" comment, I stole that from you. Thanks for your input in this matter though. I apperciate it.
    ~F~
  20. #20 Re: Supercharger coupler replacement
    Keep it clean and stay on topic please.
    Snorlax strikes again.
  1. S/C Coupler not right??
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 07-25-2012, 11:45 PM
  2. Oil pan replacment
    By chevyy1212 in forum General Tech Discussion
    Last Post: 07-25-2011, 07:46 PM
  3. Cat back replacment (How to remove)
    By mgolin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2010, 03:31 PM
  4. Which coupler?
    By karkrazy1971 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 02:40 PM
