Thread: 10 psi w/ stock pulley?!?
Results 1 to 20 of 20
  1. #1 10 psi w/ stock pulley?!?
    SE Level Member 97PAGTP's Avatar
    May 2011
    Williamsport, PA
    I have read many times that the stock pulley usually makes around 7-8 psi. I stupidly hooked my boost gauge up in the wrong location, so I fixed it on my lunch hour. On my way up the on ramp on the way back to work, my gauge hit a max of 9-10 psi at WOT. Does this seem right? My mods are in my signature, with the exception of the 3.5 pulley which hasnt been installed yet.
    1997 Dark Teal GTP coupe, Magnaflow highflow cat, Borla mufflers w/ Magnaflow tips, Wizaired, LS1 crossed drilled/slotted fronts, stock crossed drilled/slotted rears, tinted tails, clear corners, triple pod w/ Glowshift gauges, STB, chrome grilles, junk transmission, 200k+ miles...
  2. #2 Re: 10 psi w/ stock pulley?!?
    so an intake and a 3" downpipe?
    Have a cat?
  3. #3 Re: 10 psi w/ stock pulley?!?
    May 2011
    Williamsport, PA
    3" ZZP downpipe, Magnaflow highflow cat, 3" piping back to y, then 2.5" from there through Borla mufflers. Intake mods are Wizaired CAI with K&N. Stock manifolds, TB...
  4. #4 Re: 10 psi w/ stock pulley?!?
    Piping might be a tad large.
  5. #5 Re: 10 psi w/ stock pulley?!?
    Jul 2011
    B-Town, PA
    ditch the 3" DP
    Obtain SD Headers
    PROFIT!
  6. #6 Re: 10 psi w/ stock pulley?!?
    May 2011
    Williamsport, PA
    I will do headers down the road. My question is, how am I hitting 9-10 psi with stock pulley when everything I have read says 7-8 psi on stock pulley. Does this mean that I will be in the 12 psi range with my 3.5 pulley?
    fubar: where in PA?
  7. #7 Re: 10 psi w/ stock pulley?!?
    probably.
    I'd just leave it off for the time being.
  8. #8 Re: 10 psi w/ stock pulley?!?
    Air density is what it comes down to.
    If you are at 4,000 ft you are not going to see the same numbers as sea level. Sure it's possible to see 9-10psi on a stock pulley. It's not common this time of year, it's possible though.
    Is it possible that your new gauge isn't super accurate, sure.
  9. #9 Re: 10 psi w/ stock pulley?!?
    Jul 2011
    B-Town, PA
    Quote Originally Posted by 97PAGTP View Post
    fubar: where in PA?
    do them now. i got mine for 198.xx shipped to my door with saturday delivery.
    Bradford. I'm about 2hrs away from you. you don't happen to have a pulley puller do you? lol. i need to get the MPS hub on my Park Ave.
    FWIW i am seeing the MAP read 6.5psi at the shift on a 3.8" in my car after the headers. no cat. 3" to 2.5" res delete. stock Y section. modded stock mufflers.
  10. #10 Re: 10 psi w/ stock pulley?!?
    PA
    He is probably around 800ft above sea level.
    I am guessing the manifolds are holding you back and the boost gauge is a little off.
    I was running basically the same setup with the only difference being PEMs and seeing 6psi.
    2001 GSE
  11. #11 Re: 10 psi w/ stock pulley?!?
    Keep in mind guys.. Boost = Pressure backed up in the LIM that you aren't using.
    I have uh.. two pulley pullers. Wanna buy one pm me.
  12. #12 Re: 10 psi w/ stock pulley?!?
    Jul 2011
    B-Town, PA
    this. flow is king here. opening that motor up and letting it breathe > small pulley and no flow.
  13. #13 Re: 10 psi w/ stock pulley?!?
    Portland Oregon
    I agree that the manifolds are probably holding you back.
  14. #14 Re: 10 psi w/ stock pulley?!?
    May 2011
    Williamsport, PA
    Quote Originally Posted by Zef_66 View Post
    I'll have to look into PEMs, because I would rather not get rid of the DP, seeing how it is all nicely welded together. I have an extra set of manifolds, is it possible to just port the stock manifolds and crossover out to help with flow or is it a waste of time?
    How much? Willing to just Rent/loan one out? I would only need it to remove my stock pulley and install my MPS Hub.
  15. #15 Re: 10 psi w/ stock pulley?!?
    Jul 2011
    B-Town, PA
    for the cost of (new) PEMs you can buy headers.
    You will need to weld them in certain spots in order to really open them up.
    Just buy the headers and sell the DP to offset some of that cost. might only end up costing you 125 to 150 in the end and that's a steal.
  16. #16 Re: 10 psi w/ stock pulley?!?
    PA
    Damnit man! I just shipped out my ceramic coated PEMs yesterday!
    2001 GSE
  17. #17 Re: 10 psi w/ stock pulley?!?
    May 2011
    Williamsport, PA
    DAMN!!! Oh well...winter project, along with 1.8 rrs, LS6 valve springs, LS1 retainers, and Intense pushrods.
  18. #18 Re: 10 psi w/ stock pulley?!?
    PA
    Here is a good overview of what gets done to PEMs:
    W Body Store
    2001 GSE
  19. #19 Re: 10 psi w/ stock pulley?!?
    May 2011
    Williamsport, PA
    W Body Store
    Might try porting and polishing my spare set of manifolds. Thanks for the info everyone.
  20. #20 Re: 10 psi w/ stock pulley?!?
    PA
    I have a couple more spare sets if you mess them up or something.
    2001 GSE
  1. KR on stock pulley
    By Dallasneon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2010, 08:10 AM
  2. 3.5 pulley with stock pcm and K&N CAI
    By mac507 in forum General Tech Discussion
    Last Post: 01-28-2010, 11:55 AM
  3. Can I run a 3.4 pulley on a stock gtp?
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 11:25 AM
