Thread: Engine tapping noise under load and cold only
Results 1 to 8 of 8
  1. #1 Engine tapping noise under load and cold only
    SJ PR
    Hey guys,
    I have been unable to find the source of a tapping noise that manifests itself the first 5-10 minutes while the car warms up and only when the engine is under load (not in park/coasting). Basically the engine sounds like a loud sewing machine. The noise only shows up when the car is under load and from 1000rpm onwards. The noise also goes away after 5=10 minutes when the car heats up. Noise came up after I replaced my heads due to an overheat. Noise comes from the rear bank of cylinders. Ive replaced the rear lifters thinking the noise was a collapsed lifter but it was not. My rockers and pushrods are tight and do not have any play. My main issue is that I am unable to replicate the noise in my garage because the noise is only present under load. I can put the car and drive and accelerate while braking but is a pain to do by myself. Any ideas.
    Thanks.
  2. #2 Re: Engine tapping noise under load and cold only
    HUDSON
    Sounds like an exhaust leak.
  3. #3 Re: Engine tapping noise under load and cold only
    Kansas
    Quote Originally Posted by QUICKSILVER462 View Post
    Could have gotten bad heads. Do you have any mods?
  4. #4 Re: Engine tapping noise under load and cold only
    SJ PR
    No mods. Everything is stock.
  5. #5 Re: Engine tapping noise under load and cold only
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Any way to get a video of it?
  6. #6 Re: Engine tapping noise under load and cold only
    my 03 gmc had the back manifold bolt fall out, it only had a slight leak at idle and went away after it was warmed up.
    being that you just did the heads, maybe when the engine is cold try to tighten up the exhaust manifold bolts, one may have started to back out or was left snug not tight.
  7. #7 Re: Engine tapping noise under load and cold only
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    check the crossoverpipes goin to the egr valve. make sure there tight and not damaged.
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  8. #8 Re: Engine tapping noise under load and cold only
    MO
    Sounds like an exhaust leak to me as well
    <brandonl2000> LMAO D!!
  1. WTH is this tapping noise
    By dagger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2011, 10:53 AM
  2. loud tapping noise
    By blown98gtp in forum General Tech Discussion
    Last Post: 03-04-2009, 03:40 PM
  3. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
  4. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
