Thread: how do i remove this Crankshaft Sprocket(keyway damaged)
Results 1 to 2 of 2
  1. #1 how do i remove this Crankshaft Sprocket(keyway damaged)
    SE Level Member Hixc's Avatar
    Lawrence MA
    picture below. my car wouldnt start, and this is why. now how do i get this sprocket off, i have the new woodroof key
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  2. #2 Re: how do i remove this Crankshaft Sprocket(keyway damaged)
    you will need a 3 arm puller, like this, American Presto 3-arm Heavy-duty Gear Pullers - JCWhitney
    the one for 30 bucks at pep boys will do the trick, its got more adjustment with 2 holes on the arms for different applications.
  1. 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 04-08-2015, 10:14 AM
  2. Camshaft Sprocket Bolt
    By Andre in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2010, 02:23 PM
  3. Camshaft Sprocket Bolt Size?
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 11:18 AM
  4. Car Damaged by walmart shop
    By SDGTP99 in forum The Rant Forum
    Last Post: 07-25-2009, 12:32 PM
  5. Drive Sprocket Support Bearing
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2008, 05:50 PM
