Thread: Pics from My recently completed Top Swap!!(no 56K!!)
Results 1 to 20 of 21
  1. #1 Pics from My recently completed Top Swap!!(no 56K!!)
    Hoffman/Schaumburg, IL
    Before:
    Durring:
    And per Syn's suggestions and example; some labels
    Parts Going In !!!
    Note: this was a 98 TB
    After!!!!!
    ^^^Notice them Fuel Lines
    Some Random pics:
    Dex cool and Universal
    Dexcool sludge on HG
    And Since no-one on here has seen it:
    My 2-tone interior:
    ^^Ignore the Cup
    and my grills(well only one but you get the idea
    And I know there is no belt on it, cause I still have to swap the HB and put in the GTP injectors and get the tuner up and running, this is only about 85% complete
  2. #2 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    GT Level Member scoobyydooooooo's Avatar
    Houston, Texas
    very nice job,,,looks good..
  3. #3 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    I live here. UR LOSN's Avatar
    Rockford, IL
    well done!!!! give yourself a good 'ole pat on the back!
  4. #4 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    GT Level Member 04 GTP COMP G's Avatar
    Jul 2008
    Saskatchewan, Canada
    sweeeeet!!!! looks awsome
  5. #5 Re: Pics from My recently completed Top Swap!!(no 56K!!)
  6. #6 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    Oklahoma
    Did labeling everything help out?
  7. #7 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    The labeling made me feel more comfortable, but there aren't too many connectors on these motors, so I didn't really need them(each one only fits one thing)
    I do recommend the fuel lines to everyone though, easy enough to get rid of those plastic lines, and the quick connect adapters use two identical O-rings (without a little lube it is impossible to get these on)to seal around the pipe, a much better seal than the O-ring at the tip on the factory
  8. #8 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    Barksdale AFB, LA
    Where did you get the fuel lines, or was it a do-it-yourself job?
    2009 Subaru Impreza WRX STI
  9. #9 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    It was all do-it your self .... Lines and fittings came from JEGS High Performance - Your source for Edelbrock MSD Holley Mr. Gasket Moroso
    P.S. Feed line is braided SS al the way back to the filter !!
  10. #10 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    Moore, Oklahoma
    Looks good, nice job on the fuel lines. Glad you did them the right way, i've seen way too many rigged up lines on top swap projects that look so unsafe. Nice and clean...
    Shawn W. Larsen
  11. #11 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Looks good! Glad to see you got it all together ok. I used those AN quick connects on a recent swap and they really made life easy and you dont have to worry about the stock lines that way as they really get bent at bad angles going from L36 to L67 fuel lines, plus the leak nice I bit on the expensive side but well worth it IMHO.
  12. #12 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    not too expensive, less than $200 for everything including a line cutter
  13. #13 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    SE Level Member UWISHU1's Avatar
    Hanover Park, IL
    sweet fuel lines
  14. #14 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    Apr 2008
    Chillin at the Beach , VA
    Looks good. Great job man.
  15. #15 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    May 2008
    McHenry IL
    nice man starting to look like mine haha =] im very fond off your grills also because they look like mine also haha
  16. #16 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    ^^ Well, I'll still claim to have had them first
  17. #17 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    Looks sweet man....
  18. #18 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    I like those fuel lines. I think its a waste running them all they way back to the filter but a great alternative to the plastic lines.
  19. #19 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    My filter was rusted/corroded to the lines, so I figured one solid line would be better than two connections to the hard line (less chance of leaks) If the filter hadn't been rusted/corroded, I would have just gone firewall up for both
  20. #20 Re: Pics from My recently completed Top Swap!!(no 56K!!)
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    how did you make it so the fuel line would work for a fuel injected application? i would like to retain my steel lines but rid myself of all the drama of the plastic portions, what should i do? is it safe to put on the pressure side? maybe im not fully understanding this lol
    COMP G
  1. Differential COMPLETED!!
    By JCGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2008, 10:56 PM
  2. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
  3. If you recently bought an aftermarket radiator from ZZP or W-Body store
    By Gandalf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 11:06 AM
  4. 97.5 pcm to 98 swap?
    By monte0 in forum PCM Tuning
    Last Post: 01-07-2008, 10:09 AM
  5. Gear Swap PICS now up in the 4T60/4T65E section!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-31-2007, 02:07 PM
