So I am P&P my supercharger before I give it back to my tuner, as I was taking some metal off the two humps (on the left and right if you were to take off the TB an look into the inlet) I took a little too much off the right hump and I made a very small hole, Im not sure as to where I tapped into, I believe it maybe a coolant passage. I have patched the hole with JB weld and tomorrow I am planning on smoothing it out. I am just seeing if there is anything else that I need to do? Will the fix work or do I need a new housing?
From what I have read this should fix the problem, I just would like some input from people that may have anymore knowledge.
Any help is very appreicated!!
Thanks
