Thread: Bent plug tips and misfires
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
  1. #1 Bent plug tips and misfires
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    Hi all,
    I've posted a couple of things on here about my 2000 GTP that I recently purchased..well I have a couple more questions if someone may have some answers...
    First off..when I got it home...it was missing on two cylinders...we pulled all the plugs to see if there was anything noticeable..and boy was there:
    put in 6 new spark plugs...still had the miss...hooked up a friend's analyzer to it..was misfiring on cylinders 3 and 5...
    replaced plug wires on those two cylinders..still misfiring...
    got some coil packs from a junk yard...put them in..still missing..
    so I've been looking into some stuff...maybe injectors?...I have seen a lot of stuff about chipped pistons....not sure if that could play a part....
    also...when we first started the car up.....it ran for a lil while then started smoking real bad from the rear of the motor...now almost as soon as it is started..it begins smoking....
    any ideas?
  2. #2 re: Bent plug tips and misfires
    is the car modded?
  3. #3 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    I dont believe so..at least not that I can see
  4. #4 re: Bent plug tips and misfires
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I would do a compression test....
  5. #5 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    I will have to give that a shot...not entirely sure what it is..I'm not velry car-literate lol..but I'll look further into it thanks
  6. #6 re: Bent plug tips and misfires
    Dec 2010
    Canada
    Quote Originally Posted by Knightmare View Post
    It's straight forward. You can buy the tester for $30 at an auto parts or surplus store.
    Remove a spark plug, insert tester, crank engine, read compression. You need to disable the ignition prior somehow. Maybe just remove all of the plug wires?
  7. #7 re: Bent plug tips and misfires
    Jul 2011
    Edmonton, AB
    Do not just remove all the plug wires, you can wreck the coil packs.. Remove the wire harness that connects to the coil packs..
  8. #8 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    as soon as it cools down I will give it a shot....I'll keep y'all informed
  9. #9 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    any ideas on the smoke pouring out of the rear of the motor?
  10. #10 re: Bent plug tips and misfires
    Yeah..something is wrong.
    Not trying to be a wise ass here, without some good info/history I'm not inclined to know how to help you. Was the car run hard and developed the miss? Did you just buy the car?
    My one off the hip idea that I'll throw at you is for you to ensure that a plug wire from the middle coil is going to the driverside end plug on the front of the motor. Then, ensure a wire from the top coil is going to the middle plug. If those two are reversed, that explains misfires and unburned charges explains smoke from exhaust.
    You said smoke from back of motor, though. That's easy to explain. A newbie with greasy/oily hands got that all over the rear exhaust manifold. Oil + heat = smoke.
    How'd I do? c'mon..you know those plug wires being reversed would be a nice easy fix.
  11. #11 re: Bent plug tips and misfires
    is it blue smoke? does it smell like oil? it all the time, when its running?
    by the looks of your plugs you may have chipped a few pistons.
  12. #12 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    I just bought the car about 2 weeks ago..havent really messed with it much besides the things I mentioned...perhaps hamis-stated there is no smoke coming from the exhaust..just from the back of the motor....I will look into the wires..but I'm fairly certain that the wires are right
  13. #13 re: Bent plug tips and misfires
    It would be a nice fix though. As for seeing the plugs like that..yeah. It's not good.
  14. #14 re: Bent plug tips and misfires
    Feb 2009
    flintnasty MI
    chipped pistons/cracked head....
    I would just get a new longblock myself.
  15. #15 re: Bent plug tips and misfires
    Texas
    Every plug that I have seen on a GP like that has been a chipped piston. Who knows maybe you will be the first that didn't with a plug looking like that.
    Good luck
    85 Corvette
    01 TA
    03 Z06
  16. #16 re: Bent plug tips and misfires
    Jul 2011
    Edmonton, AB
    By the back of the motor, do you mean the firewall side of the motor? If so maybe valve cover is leakin oil onto the exhaust manifold...
  17. #17 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    Quote Originally Posted by 2007gpgt View Post
    yea..the side closest to the firewall
  18. #18 re: Bent plug tips and misfires
    Jul 2011
    Edmonton, AB
    Did you get a chance to do a compression test?
  19. #19 re: Bent plug tips and misfires
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    subd.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  20. #20 re: Bent plug tips and misfires
    Jul 2011
    Frederica, DE
    No i haven't had a chance for a compression test yet..hopefully tomorrow...it annoys.me.i can't.work on it every day..but too many irons in the fire..soto speak...
  1. Misfires in Cyl 4
    By mousemonster1232 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2011, 02:38 PM
  2. Spark Plug tips gone!!! UPDATE 2/6/2011
    By MidnightBlue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2011, 09:22 AM
  3. Bent rim
    By dengnath in forum Tires & Wheels
    Last Post: 01-07-2011, 08:19 PM
  4. Mandrel Bent Pipes vs. Regular Bent - New Exhaust
    By roundbox52 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 10:46 AM
  5. WOT misfires
    Last Post: 11-12-2008, 08:58 PM
