Thread: IC Boost Pressure
Results 1 to 10 of 10
  1. #1 IC Boost Pressure
    Vancouver, WA
    I think I'm having a leak issue with my garleak gasket, just want to see what you guys think. I have a Gen V with a 3.4" pulley on a WBS 2.25" IC. I'm only seeing high 7's through most of the rpm range and it will peak usually right under 10. Seems a lil low to me, thoughts?
    Slowest 'Cooled Gen V ever
  2. #2 Re: IC Boost Pressure
    Akron Ohio
    on my stock 3.8 I have hit 9 so yep sounds like a leak.
  3. #3 Re: IC Boost Pressure
    Vancouver, WA
    You have 9psi on a stock pulley with headers, wtf?
  4. #4 Re: IC Boost Pressure
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    what are your ltft's? If they are 16.4 at idle or basically at all times ten you have a leak. Im goign through that right now and cant seal my core for **** no matter if i use garleak or oem gaskets. Im still thinking im leaking from somewhere else.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  5. #5 Re: IC Boost Pressure
    Akron Ohio
    Quote Originally Posted by footballplaya3k View Post
    There in the basement lol
  6. #6 Re: IC Boost Pressure
    Sounds normal to me.
    Similar numbers here.
    High comp block though.
  7. #7 Re: IC Boost Pressure
    Vancouver, WA
    Good to here. Shouldn't yours be a lil higher then?
    I'll check my LTFT's today, I've been neglecting them.
  8. #8 Re: IC Boost Pressure
    Nope.
    Boost pressure is a sign of restriction (related to flow)
    Since our motors both use the same camshaft, rockers, heads(flow numbers should be nearly identical), headers, intercooler core... I'd say they flow pretty similarly.
    Just can't run as much timing because the compression gets in the way.
  9. #9 Re: IC Boost Pressure
    Vancouver, WA
    Found a SC bolt just sitting in place, not tight at all. Looking like I'm at 7.5 to just over 10 now.
  10. #10 Re: IC Boost Pressure
    Vancouver, WA
    Nope.
    Yeah idk why I thought boost would be effected by your compression.
  1. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  2. Boost and oil pressure Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:40 AM
