Thread: trouble starting after topswap/build
Results 1 to 11 of 11
  1. #1 trouble starting after topswap/build
    Milwaukee
    having some issues starting the car. build is xp cam, ls6 springs, headers,ported lim, zzp s3 ic, 42# injectors, ported blower ported tb, lq4 maf. heres a vid of what happens when we crank it. we have spark, fuel, no vac leaks. we have an idea of what might be wrong but just trying to see what others have to say just in case we over looked somehting
    video
  2. #2 Re: trouble starting after topswap/build
    Whats the PCM tuned for?
    Not sure how you can check for vac leaks without the motor running.
    Have you done a compression test yet?
    Have you tried giving it gas to see if it starts?
  3. #3 Re: trouble starting after topswap/build
    Omaha, NE
    Tune would also be my first guess.
    Atleast make sure the values are correct for the maf and injectors.
  4. #4 Re: trouble starting after topswap/build
    My car started after top swap with following parts:
    stock L36 PCM
    L67 TB/MAF
    42.5's
  5. #5 Re: trouble starting after topswap/build
    Milwaukee
    the tune is fine, and when cranking we watcheed the MAP table and saw pressure. i have not done a compression test, but that will be something i do tomorrow. or thurs. the values for the injectors and maf are correct
  6. #6 Re: trouble starting after topswap/build
    That doesn't mean you dont have a vacuum leak.
    What gasket did you use between the lim/core/s/c?
    If you have spark, fuel, injector and maf tables are correct then all that could be off is the cam timing.
    Have that golden picture? (timing dots lined up)
  7. #7 Re: trouble starting after topswap/build
    Grand Island, Nebraska
    It wouldnt hurt to put a stock pulley on it to get it running either if you have one.
  8. #8 Re: trouble starting after topswap/build
    SE Level Member RegalGShocker's Avatar
    Milwaukee, WI
    Let me explain a little more...
    1st- PCM is set to stock 99 L67 file w/ LQ4 MAF and 42.5 scaled on the injector table
    2nd- yes there is spark but timing is off so bad smoke is coming out the valve cover which leaves me to believe the exhaust is exiting partially out the intake valves. It gives a loud backfire after awhile of cranking. During firing it hits a dead spot every time it goes through all 6 cylinder and lands on one. (hear the video) Sounds exactly like having timing retarded too much.
    Scan shows 10* timing exactly when cranking across the board.
    3rd- There is vacuum showing on the scan but this does not eliminate all vac leaks I know.
    4th- Fuel pressure is 42ish when cranking (adjustable regulator)
    5th- Coil packs and wires have been checked and are installed correctly.
    BTW yes it was flooded after a while but holding the gas to the floor will clear this out which we did and tried again.
  9. #9 Re: trouble starting after topswap/build
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Is the balancer in the keyway? That would be my first choice to check
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: trouble starting after topswap/build
    Milwaukee
    so we tried my stock l36 tune with maf table, injector table, and adjusted timing. still no go. it sounds mechanical, and i know i dont have the golden pic of the timing set lined up, but im am 99.9% sure it is lined up. i want to exhaust all options before pulling the motor and checking.....
  11. #11 Re: trouble starting after topswap/build
    Milwaukee, WI
    Not questioning your abilities but having it misaligned somehow without even knowing it maybe the problem. It sounds EXACTLY what the problem is. You seen the guy with the key ways installed upside down. I guess you don't know unless you done it. Never thought stuff like this could be put on wrong.
  1. Starting the new build soon:)
    By bballa0740 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 09:34 PM
  2. 98 GTP Trouble starting while cold
    By silverPGP in forum General Tech Discussion
    Last Post: 06-12-2010, 07:02 PM
  3. having trouble starting my car
    By gonzo915gp in forum General Tech Discussion
    Last Post: 08-04-2009, 03:47 PM
  4. starting car trouble
    By rochaedkj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 01:12 AM
  5. trouble starting, misfire
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2008, 11:55 PM
