Thread: Gaskets
Results 1 to 7 of 7
  1. #1 Gaskets
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    Hi guys,
    I will hopefully be new to this section soon. I am doing the l32 topswap on my 05 and I was wondering what gaskets (head, intake, ect.) you guys use for your s/c engines. TIA
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: Gaskets
    May 2008
    staten island,NY
    you do know that you cant use the HV3 with the supercharger right?
  3. #3 Re: Gaskets
    Apr 2008
    ny
    Quote Originally Posted by QwikGT View Post
    Yes but I am not doing the swap right away so for now I will use it then when I am done I will see if I can sell it
  4. #4 Re: Gaskets
    Bastard Reptile's Avatar
    Kansas City, MO
    Head gaskets can be bought fairly cheap at an auto parts store. If you go to the dealers for the gaskets, I'll give you the numbers that you will need. Make sure to get the metal LIM gaskets...yes they're expensive, but you do NOT want the plastic ones.
    GM Head set (this includes the top end gasket set if you decide to go that route) 89017824
    LIM gaskets 89017825
    GenV gasket (assuming you're doing this since you said L32) 12574474
    The 2 little yellow o-rings on the LIM 24501563 (each)
    Valve Cover Gaskets 24503937 (each)
    Coolant elbows! these are crummy and they always break. 24503423 & 12565082
    Throttle body seal (GenV) 12576730
    You might want to get you an o-ring kit for the injectors, just for peace of mind. I'm talking about the ones that actually go onto the injectors. The kit from GM is ridiculously high, so you can be safe with getting them from an auto parts store.
    You're also going to need all new head bolts as well along with new rocker bolts.
    Rocker bolts (12) 24503515
    Long head bolts (8) 25527831
    Short head bolts (8) 88891770
  5. #5 Re: Gaskets
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Quote Originally Posted by Reptile View Post
    Damn, thats allot of info!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  6. #6 Re: Gaskets
    Apr 2008
    ny
    Thank you that is alot of info but very useful.
  7. #7 Re: Gaskets
    Kansas City, MO
    I try.
  1. Where to get TOG Donut Gaskets ? Locally ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2008, 07:01 AM
  2. Snapped some UIM gaskets, should I drive?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2008, 05:43 AM
  3. reuseable gaskets?
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2008, 08:38 PM
  4. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
