My car randomly dosent start at times and it has no spark. ive change the cam sensor and ICM and stilll no luck . and then randomly it will start. after reseting the PCM by leaving the batt unhooked. anyone know what these symtoms are?
Well when it wont start, does it try to crank over? Also does your interior lights work when its not starting?
yes it cranks over and lights work it just wont start. No spark until i disconect the batt for 30 mins and reconect it.
You replaced the two uncommon items. The crank sensor is the common issue. Likely replacing that will solve the problem
Crank sensor being changed today. Will
Keep youse updated
was the crank positioning sensor:P runs good now.
