So a while after my header install i found that the collector was rubbing on my power steering lines. So i replaced the lines (probably one of the most frustrating things i've ever done) but now after my first start up my speedo doesnt work. All guages work, HUD works but does not show speed. Now i know theres a speed sensor right under my power steering pump. Its plugged in. But i also heard or another kind of speed sensor on the hub. What could be my issue? My transmission also feels lik i dont have overdrive. I kno tjis can be a totally different issue, but i was told the speed sensor influences the transmission. Any kind of info will help
