Thread: 01 gtp firing order
Results 1 to 10 of 10
  1. #1 01 gtp firing order
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    need to know the firing order asap... changed plug wires today and now car wont start is it
    front 1 5 3
    rear 4 2 6
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: 01 gtp firing order
    i wont to says it 123456..i thats more then likly wrong..as long as you had the right plug on the same coil as clyinder..like coil 1 to cly 1,, it should work
    SMGPFC Member #10
  3. #3 Re: 01 gtp firing order
    Charles City, IA
    135 up front
    246 in the back
    SMGPFC Two Nipple General
  4. #4 Re: 01 gtp firing order
    Galveston, Texas
    thanks guys
  5. #5 Re: 01 gtp firing order
    Firewall
    2....4.....6
    Engine
    1....3...5
    Coil packs
    Top:3/6
    Middle: 2/5
    Bottom: 1/4
    The coils fire both towers at the same time, so if you put the 4 and 1 wires on either of the bottom coils posts...you are all set.
  6. #6 Re: 01 gtp firing order
    Galveston, Texas
    Car aint running that same after this bought new coils and oem wires could the plugs maybe messed up
  7. #7 Re: 01 gtp firing order
    Galveston, Texas
    Should i buy better plugs then al104s maybe NGK iriduims?
  8. #8 Re: 01 gtp firing order
    what are they gapped at, and whats the car doing? Sluggish, misfires? details
  9. #9 Re: 01 gtp firing order
    Galveston, Texas
    its running sluggish, and misfire at idle was noticeable and could here it in the exhaust, also when driving on highway felt it misfire when going over under pass or a bridge, full throttle wasn't normal either.
  10. #10 Re: 01 gtp firing order
    GT Level Member GtpKo's Avatar
    Best place on Earth
    Check your new coils for cracks. This exact thing happened to me after 3k miles on new coils. I threw in lower mileage stock junkyard ones, been fine ever since.
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  1. Firing order
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 06-10-2010, 12:31 PM
  2. firing order starter like sound?
    By rkjlow in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2009, 07:09 PM
  3. still not firing
    By jem0103 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2009, 03:48 PM
  4. not firing
    Last Post: 07-06-2009, 06:24 PM
  5. 06 gp not firing on 2-4-6 cyl
    By melnrob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2009, 05:19 PM
