Thread: unreported misfire at idle
Results 1 to 8 of 8
  1. #1 unreported misfire at idle
    ontario
    Hey everyone,
    here are the details : 02 gp with the ssm90 3.8 pulley, tb spacer, zzp stage 1 tb, fuel logs, autolite 103's, zzp 10.2mm wires, zzp 2.5" downpipe with high flow cat, k&n cai.
    my issue: every once in a while, not all the time, i will come to a stop and the car will be idling. i will get what feels like a misfire, some of my passengers have even commented on it, above idle everything is ok. Now with a scan tool there are no codes reported.
    does anyone have any ideas? kind of annoying when your sitting in the car
    thanks
    Mike
  2. #2 Re: unreported misfire at idle
    These car are well known to misfire at idle when modded. Its pretty normal for it to happen.
  3. #3 Re: unreported misfire at idle
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    X2, mine did the same till I started tuning myself. You really need a Plog for that 3.8 pulley. Id just get headers since you have that tiny downpipe aswell.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: unreported misfire at idle
    Florida
    ^^ X2
    Mine would misfire under prolonged idle.
    Damn you....make that X3
  5. #5 Re: unreported misfire at idle
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Mine is smooth as glass.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  6. #6 Re: unreported misfire at idle
    Florida
    Nah, it still misfires, you just cant tell, XD
  7. #7 Re: unreported misfire at idle
    Dec 2008
    Alabama
    and that's all that matters.
  8. #8 Re: unreported misfire at idle
    try running autolite 605's...
  1. Odd rough sound at idle...possible misfire?
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2011, 01:06 AM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. Another idle surge/misfire problem with multiple codes
    By Justinzoso in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2010, 11:43 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. Random dieing at idle + occasional misfire = me pissed off
    By mark455 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 09:22 PM
