Thread: best mufflers
Results 1 to 15 of 15
  1. #1 best mufflers
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hi I am wondering what mufflers I should get to produce a deeper louder sound to my grand prix. I want to do this without installng a full cat back. I am looking at something like flowmaster 40 series or cherry bomb pros maybe glasspacks. Also I believe I will need 2 mufflers with 2.25 inlets? Corret me if Im wrong. 2004 gtp comp g.
    Thanks!
  2. #2 Re: best mufflers
    St. Louis
    Do not use ANY chambered muffler (flowmaster). They will sound like junk and produce a bunch of interior drone.
    Do a quick search for "mufflers" here and see what comes up. I know this was just brought up last week. Most people recommend removing the resonator and installing a 25" glasspack and keeping the stock mufflers. You can also go with Borla's as they seem to produce the best tone.
    If you're looking to get that V8 sound from the 3800 then good luck. I'd get a GXP if that's what you're after.
  3. #3 Re: best mufflers
    May 2011
    Ontario
    how much of a difference would a res delete for a glasspack make in terms of loudness? Any one done that here?
  4. #4 Re: best mufflers
    youtube and the search button man.
    This topic has been covered about a million times.
    Res delete = rasp, which = crap.
  5. #5 Re: best mufflers
    Ugh.
    Guy.
    Read.
  6. #6 Re: best mufflers
    May 2011
    Ontario
    All I found is that chambered mufflers sound like crap on 3800s. Nothing saying how a glasspack for a res sounds. Does this give it a raspy sound? I def do not want rasp.
  7. #7 Re: best mufflers
    a glasspack in the same spot as the res, just makes the sound a smidge different and you will get no rasp.
    and yes, no chambered muffers ever
  8. #8 Re: best mufflers
  9. #9 Re: best mufflers
    May 2011
    Ontario
    ya none of those give much info on res delete for a glasspack thanks
  10. #10 Re: best mufflers
    Really?
    because maybe you should actually click on this one then.
    http://www.grandprixforums.net/04-in...vid-46997.html
  11. #11 Re: best mufflers
    St. Louis
    Here is a thread that talks about removing the resonator and there is a vid in there as well.
    http://www.grandprixforums.net/remov...ound-4099.html
    Just do a search for this as there are many threads out there.
    blue, I tried to save him before the wolves jumped in
  12. #12 Re: best mufflers
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Where can i get the 25'' glasspack from?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  13. #13 Re: best mufflers
    napa, oriellys, autozone, summit racing, jegs etc etc etc etc
  14. #14 Re: best mufflers
    Jegs or Summit...cheap.
  15. #15 Re: best mufflers
    St. Louis
    Dynomax and Thrush come to mind. Check Oreillys and Autozone.
  1. Mufflers
    By Everblades2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-21-2010, 11:26 AM
  2. best mufflers
    By grandprixxx94 in forum General Tech Discussion
    Last Post: 08-18-2010, 01:24 AM
  3. new mufflers
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2010, 04:25 PM
  4. mufflers on GT
    By CTKGP09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2009, 04:26 PM
