Thread: Are all 3800 heads created equally?
Results 1 to 9 of 9
  1. #1 Are all 3800 heads created equally?
    slc Utah
    I am going to change the head gasket on my 2004 GTP comp G and want to get the heads done before I tear into it. I am going to go to my local pick-n-pull and get some heads but wanted to make sure that all 3800 heads are the same. Can I just pull any head from a Pontiac or Buick that has a 3800 engine and have them done? Does the car have to be supercharged? Are there certain years that are beter then others? Thanks in advance for your reply.
  2. #2 Re: Are all 3800 heads created equally?
    the heads are not the same. they are different between supercharged and NA and L67 and L26.
    And why are you changing the headgaskets in the first place???????
    These cars NEVER have head gasket issue and are never even a part of normal maintance.
  3. #3 Re: Are all 3800 heads created equally?
    slc Utah
    Well thank you for your rapid reply but unfortunately for me my head gasket has gone out…… I wish that the NEVER that you said was the case on my vehicle. I am open to ideas if you can tell me what else it could be other than the head gasket. I changed the LIM even though that would not allow exhaust to get into the coolant but after the change the hydrocarbon coolant test shows that exhaust is getting into the coolant. If it isn’t the head gasket then it could be a cracked head (the reason that I want to have a redone set here when I tear into it). I guess you should change your NEVER to almost never. Do you know of anything else it could be?
    Anyway…… can someone please answer my original question about which cars will work for me and which cars wont?
  4. #4 Re: Are all 3800 heads created equally?
    96-97 heads were prone to cracking between the cylinders. The casting number was then changed for 98-03 with a different head being produced 04+
    96-03 the motor was labeled an L67, 04+ it was labeled an L32. Yes there is a difference between charged and not charged. Mainly it's the injector location. L67's have holes in the heads for the injector and L36 do not.
  5. #5 Re: Are all 3800 heads created equally?
    GTP Level Member
    Pittsburgh
    Also the later 04's and 05+ have larger Valves
    2003 SSEi,
  6. #6 Re: Are all 3800 heads created equally?
    Pennsylvania
    Quote Originally Posted by 2003 SSEi View Post
    ...really?
  7. #7 Re: Are all 3800 heads created equally?
    Ever so slightly.
    But the casting is still the same?
    1.83" intake valves (instead of 1.80" as on Series II) and 1.52" exhaust valves were introduced in 2003 engines, just before switching to Series III.
    As per wikipedia.
  8. #8 Re: Are all 3800 heads created equally?
    Really Slow...but not enough to make a difference.
  9. #9 Re: Are all 3800 heads created equally?
    Pennsylvania
    Man, I keep learning new stuff all the time. Love it.
  1. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  2. **FIXED!** Fixing One Problem Created Another...
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-09-2010, 08:31 PM
  3. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  4. Custom created hood
    By GOINDEF in forum Visual/Body Modifications
    Last Post: 08-07-2008, 01:24 PM
