Thread: ticking at cold start...
Results 1 to 15 of 15
  1. #1 ticking at cold start...
    michigan
    So recently I've been getting a ticking from under the hood, which goes away after a few minutes. I was thinking exhaust gasket leak somewhere? Or could it be internal? I sure hope not! Anyone else have this problem before?
  2. #2 Re: ticking at cold start...
    Waukesha, WI
    i have the same problem..
    maybe lifter?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: ticking at cold start...
    michigan
    Uuugh, that was in the back of my mind! I can't afford any more repairs right now!
  4. #4 Re: ticking at cold start...
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    try running some seafoam and then changing the oil
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: ticking at cold start...
    michigan
    Ran some seafoam but that's just a temp fix. So im looking at replacing lifters, what parts will I need for this/best place to get them/best brand etc. Upgrade if possible?
  6. #6 Re: ticking at cold start...
    Hagerstown,Md
    Why would it be a temp fix? It could have been a sticking lifter. Which once clean will be fine
  7. #7 Re: ticking at cold start...
    michigan
    Ran fine once I put it in, just went and started it up and its still ticking! :-/
  8. #8 Re: ticking at cold start...
    michigan
    Well, service engine light when on this morning.....not too excited about that! First time I've seen that since I've had the car.
  9. #9 Re: ticking at cold start...
    michigan
    Cyl 4 misfire is what the scan is showing.
  10. #10 Re: ticking at cold start...
    michigan
    How would I check the oil pressure? I don't have a gauge. I want to make sure its all getting oil.
  11. #11 Re: ticking at cold start...
    SE Level Member kenizzle36's Avatar
    Apr 2011
    Menasha, Wisconsin
    I had the same problem. For me it was what is called dry start where oil isnt sitting in the top end. Go and get some lucas oil treatment. Will say on the jug prevents dry start. Buy a quart of that and then the rest regular oil you would use and change your oil. I did that and the next morning no more tic. Good luck
  12. #12 Re: ticking at cold start...
    Quote Originally Posted by twol8uluz View Post
    buy a oil pressure gauge of your choice, it installs in place of the stock sensor above the oil filter.
    easiest way i've found to get to it is to remove the pass side front wheel and reach into it.
  13. #13 Re: ticking at cold start...
    michigan
    Cool! Ill try that then first before I start freaking out n rippin my engine apart. Lol
  14. #14 Re: ticking at cold start...
    Pennsylvania
    Check your spark plugs, homie.
  15. #15 Re: ticking at cold start...
    michigan
    Update, threw some seafoam in and seems to have got rid of the ticking.....for now. Thanx! Ill give it an oil change soon and see what happens after that.
  1. cold start smoke
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 09:42 PM
  2. Cold Start Hissing
    By SuperSport in forum General Tech Discussion
    Last Post: 07-24-2009, 12:56 PM
  3. Ticking at start up
    By Nick24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2009, 08:12 PM
  4. Cold Start Injectors
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 01:20 AM
  5. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
